Author Topic: RCD300 & Ipod connector in armrest - Poor connection  (Read 3949 times)
Offline edd30
« on: October 05, 2014, 06:21:07 pm »
Hi,
I've just got myself a ed30. It has the boggo RCD300 and Ipod connector kit, looks official Audi. Problem is that I get no music unless I'm putting pressure on the Ipod. I guess the connector itself is shafted.
Any one know where (and if) I can get a replacement ? Part number ?
Thanks!
Re: RCD300 & Ipod connector in armrest - Poor connection
« Reply #1 on: October 05, 2014, 07:05:04 pm »
Do you have a plastic sleeve to stabilise the ipod when in the dock?
Offline edd30
« Reply #2 on: October 05, 2014, 07:54:53 pm »
Yes, but it is very wide. Needs downwards pressure to make good contact. Flaps about in the slot. Is there another bit (that I'm missing) which holds the device centred ?
Offline Jkay
« Reply #3 on: October 05, 2014, 08:07:48 pm »
Sorry for butting in but when there is a thread here i thought I'd use it rather than create a new one.  :innocent:
I have a similar setup in my GTI and it wont work with my iPhone 4S or iPod 2nd gen. I press the CD button twice but nothing happens on the radio. It charges the phone and iPod so the cable is wired up.
Anybody able to shed some light? Is it software related or is there something else I'm missing  :scared:
'07 GTI
Offline edd30
« Reply #4 on: October 05, 2014, 08:28:49 pm »
I'm ordering an Ipod extension cable to see if that helps, as it should give a better connection, especially if I wedge it down with something or araldite th e thing in!
Offline PhilNUK
  • -Given: 32
« Reply #5 on: October 05, 2014, 08:41:12 pm »
My Ed30 came with a bag of plastic adapters that are suited for all the diff size ipods/phones so they are held firmly over the connection
Offline edd30
« Reply #6 on: October 05, 2014, 11:01:57 pm »
Thanks Phil. So I need to get hold of the adaptors ... dealer I suppose or ebay
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #7 on: October 09, 2014, 12:05:40 pm »
Those docks suffer badly with dry joints. That's why loads of people upgrade to media kits
« Last Edit: October 30, 2014, 06:54:36 pm by DamoP »
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline wilsy_
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,86723.msg952943.html#msg952943
« Reply #8 on: October 10, 2014, 07:36:55 pm »
I had the same problem, so removed the connector from the armrest, and attached an extension cable, so I could leave my phone in the cup holder. Worked a treat.
Offline edd30
« Reply #9 on: October 12, 2014, 01:39:16 am »
Received my extension lead today. It didn't work - no charging, no music. Plugging the pod directly into the arm rest dock charged the pod ok and intermittent music. Tested the lead with the charger, worked ok. Bizzare. The lead/plugs may be missing some pins or connections.
How can I remove the dock from the armrest ? Must be a how to somewhere. Where does the other end terminate ? I'll see if I can replace it.
Offline edd30
« Reply #10 on: October 14, 2014, 11:36:38 am »
Contacted the seller. Looks like I ordered the wrong one - should've got one that is marketed as with A/V, the one I got was power only.
So I've ordered this now: http://www.ebay.co.uk/itm/230600138549
Offline edd30
« Reply #11 on: October 30, 2014, 12:25:44 pm »
Well I received the ipod extension cable - same problem. Works ok with pressure on the plug.
Is there a "HOW TO" retrofitting /removing these things or taking the armrest apart?
Hopefully I can do something with the socket end, worst case would be to put a new cable in.
Can I connect a MDI to the RCD300 to get the track listings etc or will I be better off getting one of those ebay double DIN units that do all this?
Offline DamoP
  • -Receive: 115
« Reply #12 on: October 30, 2014, 06:56:09 pm »
funny you shjould mention this, ive taken a load of pics today for a how to on
changing a head unit
fitting an armrest
fitting an armrest dock and what cables to use
and fitting a bluetooth
Offline DamoP
  • -Receive: 115
« Reply #13 on: October 30, 2014, 06:57:11 pm »
and no mdi only work on the 3rd generation head units, RCD310.510,RNS310,315,510
Offline edd30
« Reply #14 on: October 30, 2014, 07:05:32 pm »
Damo - Good timing!
I'd like to sort it out - photos / description will help me avoid destroying the interior !
I'll test drive your instructions if you like.
Shame about not working with the MDI. I was looking at the RNS500, but the cost puts me off. Considering the top end android based double din units, once my finances recover and I've sorted out the more important tasks, like replacing the Landsail ditchfinders.
Edd
