Author Topic: torque for front drive shaft bolt  (Read 35824 times)
Offline njdudsbury
« on: October 05, 2014, 08:54:17 pm »
What is it????
Offline doylebros
Re: torque for front drive shaft bolt
« Reply #1 on: October 05, 2014, 09:05:42 pm »
You need to know if M8 or M10 bolts fitted ( new bolts should be used)
First initially tighten diagonally to 10 NM then for
M8 - 40NM
M10 - 70 NM
« Last Edit: October 05, 2014, 09:14:47 pm by doylebros »
Offline njdudsbury
« Reply #2 on: October 05, 2014, 10:53:24 pm »
Sorry I meant hub bolt the big hex head one!
Offline doylebros
« Reply #3 on: October 06, 2014, 10:27:30 am »
200NM with wheel off the ground then an extra 180* when the wheel is on the ground.
New bolt or you may regret it later!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #4 on: October 06, 2014, 10:45:27 am »
Be careful 200NM + 180 deg. Is the old style bolt.
12 point bolt is 70nm + 90 deg.
05 | Tornado Red | DSG
Offline doylebros
« Reply #5 on: October 06, 2014, 10:56:59 am »
That's correct above for a ribbed new bolt but if not ribbed it's still the same values as posted previously as they come ribbed and none ribbed!!!!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #6 on: October 06, 2014, 11:03:04 am »
Just incase anyone is unsure.
Old style bolt.  200NM + 180 deg
12 point bolt. 70nm + 90 deg
Offline doylebros
« Reply #7 on: October 06, 2014, 11:10:59 am »
As I said the "new style" comes ribbed and un-ribbed with the same part number for both but two different torque values!
Part number WHT 005437 - 12 pointS price £3.99 full retail inc vat.
Offline doylebros
« Reply #8 on: October 06, 2014, 08:43:31 pm »
I think this post I found elsewhere will help explain this best
Thanks for the help and feedback guys, much appreciated!
After much trawling of the net I found this Golf workshop manual which confirms the Torquing procedure.
The torque value and angle are the same for the new 12 point bolts (part no. WHT005437) as for the old 6 sided bolts: 200Nm then 180 degrees.
The lower value quoted in the Haynes Manual for '12 point bolts' actually relates to 12 point bolts WITH RIBBING on the face of the head. Illustrations and full details on this link:
Volkswagen Workshop Manuals > Golf Mk5 > Running gear, axles, steering > Front suspension, drive shafts > Removing and installing drive shafts > Removing and installing right drive shaft with (push-on) constant velocity slip joint
http://workshop-manuals.com/volkswagen/golf-mk5/running_gear_axles_steering/front_suspension_drive_shafts/removing_and_installing_drive_shafts/removing_and_installing_right_drive_shaft_with_(push-on)_constant_velocity_slip_joint/
Distinguishing features between twelve-point head bolt with ribbing and twelve-point head boltwithout ribbing.
The twelve-point head bolt are only distinguishable on the contact surfaces -arrow A- and -arrow B-.
I - Twelve-point head bolt with ribbing -arrow A-
II - Twelve-point head bolt without ribbing -arrow B-
– Install wheel and tighten bolts or nuts → Chapter.
Specified torques
Component Specified torque
Swivel joint to cast steel suspension link
t Use new nuts
60 Nm
Swivel joint to sheet steel or forged aluminium suspension link
t Use new nuts
100 Nm
Drive shaft to wheel hub „twelve-point head bolt with ribbing“
t Use new bolt
70 Nm + 90°
Drive shaft to wheel hub „twelve-point head bolt without ribbing“
t Use new bolt
200 Nm + 180°
This link also explains full procedure:
Volkswagen Workshop Manuals > Golf Mk5 > Running gear, axles, steering > Front suspension, drive shafts > Removing and installing drive shafts > Loosening and tightening twelve-point head bolt, without ribbing, securing drive shaft
http://workshop-manuals.com/volkswagen/golf-mk5/running_gear_axles_steering/front_suspension_drive_shafts/removing_and_installing_drive_shafts/loosening_and_tightening_twelve-point_head_bolt_without_ribbing_securing_drive_shaft/
« Last Edit: October 06, 2014, 08:45:39 pm by doylebros »
Offline samb377
« Reply #9 on: October 06, 2014, 09:18:49 pm »
I can vouch for the difference, having taken off old bolts with ribbing and installed some new bolts without ribbing.
I'm not sure I quite managed the 180 degrees, it's a real b'atch!
Offline njdudsbury
« Reply #10 on: October 07, 2014, 01:05:05 pm »
Put it this way mine was never torqued up to that figure of 200 NM + 180 degrees as it come un done dead easy with a lot smaller bar than I tightend it up with.
If you put the orignial figure on of 70NM + 90 degrees the bolts is over 200NM as I checked it afterwards to make sure and the torque wrench clicked at 200NM without moving.
The resultant end load in the bolt is the important bit which should be the same irrelevant of the configuration. Mine is staying like that. The torque of 200NM + 180 must be massive!
Offline mcgc0
« Reply #11 on: March 10, 2023, 01:29:40 pm »
A quick resurrection of this topic to ask a couple of questions;
- Is it a given that all 'new' bolts are, or should be, the 12pt type (ribbed or unribbed)?
- Just picked up a boot kit from Eurocarparts to find that, despite being shown in the description, there is no hub bolt in the box. OK to reuse (with thread lock) the one taken off?
- The new boot is also made of polyethylene plastic. Is that the norm these days (i.e. rubber versions gradually being replaced with the 'plastic' version, but equally as good)?
« Last Edit: March 10, 2023, 01:33:29 pm by mcgc0 »
Offline rxpx69
« Reply #12 on: October 15, 2023, 04:40:39 pm »
I bought an SKF set of outer CV joints and they came with the old style bolt, the old ones on the car were an 17mm allen hex which caught me off guard as who has one of those!  :scared:
Offline terrier
  • -Receive: 38
  • My Ride: GTI now gone
« Reply #13 on: October 15, 2023, 05:37:26 pm »
Someone been there before you :signLOL: No washer,flanged bolt  :thinking:
