Author Topic: Terrible rattle from the rear  (Read 1153 times)
Offline GTi-Andy
« on: October 06, 2014, 07:07:02 am »
Hi guys
I've got a terrible and annoying rattle coming from the rear of the car.
It's still there when I take out the parcel shelf, so it's not that.
Any ideas where I should look?
So much for keeping it standard!
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Terrible rattle from the rear
« Reply #1 on: October 06, 2014, 07:21:14 am »
Could be the boot lid rattling against its stoppers?
You can adjust the stoppers to sit tightly against the boot IIRC
dansmith180
« Reply #2 on: October 06, 2014, 07:53:47 am »
Check the boot trims, does it sound plastic or metalic? If metallic could be something the the spare wheel well.
Offline OSB
  • -Given: 32
« Reply #3 on: October 06, 2014, 08:00:32 am »
I stopped one rattle by removing and properly refitting the tailgate inner plastic cover. Bit of a pain to do. I also clipped some loose wires behind the cover while I was at it.
The other annoying rattle was from the rear light cluster. Took it apart and super glued part of the reflector in place. It's just clipped together for normal assembly and works loose. There is a thread about it somewhere on here ...
Offline GTi-Andy
« Reply #4 on: October 06, 2014, 08:36:52 pm »
Thanks for the replies, gives me something to look for.
Defo sounds like a plastic rattle rather then metal though.
