Author Topic: 8P sportback.  (Read 5816 times)
Offline nicsabers
Re: 8P sportback.
« Reply #15 on: October 14, 2014, 06:40:51 pm »
B4 aren't compatible with lowering springs. Get the B8 instead or wait till you can get them. The B4 won't last what they're supposed to with those springs. :wink:
as in they won't fit ? or they are a good match ?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: 8P sportback.
« Reply #16 on: October 14, 2014, 07:00:28 pm »
They'll fit but they'll wear out much sooner than normal. B8 will last as expected.
Offline nicsabers
Re: 8P sportback.
« Reply #17 on: October 14, 2014, 07:02:35 pm »
They'll fit but they'll wear out much sooner than normal. B8 will have the normal lifetime.
I have a non s-line so i was thinking this could be a slight upgrade, even if they last 1.5-2 years I will be happy, then for for b8's when they die.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: 8P sportback.
« Reply #18 on: October 14, 2014, 07:08:01 pm »
B4 are the same as stock. B6 are the same as sport suspension and B8 are for lowering springs.
I don't know how long they will last, it depends on the roads and miles you'll drive.
Offline Jeffchiz
Re: 8P sportback.
« Reply #19 on: October 14, 2014, 07:18:04 pm »
as above b4s are same as standard, i would use them with a 20mm drop but any lower then the b8's are the ones to use
Offline nicsabers
Re: 8P sportback.
« Reply #20 on: October 14, 2014, 07:20:31 pm »
On their web site they quite they are fine to use with a lowering spring of up to 40mm. I only drive from Nottingham to Hampshire on motorways so its not going to take a battering.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: 8P sportback.
« Reply #21 on: October 14, 2014, 07:29:09 pm »
Yeap, motorways should be fine for what you're after. :smiley:
