Author Topic: How do I remove this part of the Drivers side handle  (Read 1727 times)
crs834
« on: October 10, 2014, 10:04:04 pm »
Can't figure out how to remove this part of the handle.. Has anyone got any idea? Did some searching but only came up with with removing the part with the switches
I want to remove it as I'm going to remove the rubber coating and plasti-dip it!
Thank you
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: How do I remove this part of the Drivers side handle
« Reply #1 on: October 10, 2014, 10:19:20 pm »
Wanted to do the exact same thing as you. From memory it required removal of the door card to get to the screws at the back. Similar to the passenger side.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #2 on: October 10, 2014, 11:26:31 pm »
Its part of the door card if i remember correctly
Offline v4rley
  • -Receive: 104
« Reply #3 on: October 11, 2014, 07:17:39 am »
Guessing you trying to move the middle part? It does come off, it clipped in both end, push it straight back towards the door card
Offline DDM
« Reply #4 on: October 11, 2014, 11:31:54 pm »
as above, look closely at either side and theres a clip you pull back slightly and it slides away from you then off.
crs834
« Reply #5 on: October 13, 2014, 06:15:27 pm »
Thanks guy, tried pushing a clip (not quite sure which one to be honest) and it just slid off! Couldn't tell you how to do it exactly though as it kind of just fell off in my hand and it was dark! :happy2:
