Author Topic: Bury Car Kit - RNS310  (Read 3234 times)
Offline akbarirfan
  • -Given: 81
« on: October 11, 2014, 07:53:32 pm »
Hi Guys,
Does anybody know how I can get this to work this the RNS310?
Thanks,
Irfan
Offline J400uk
  • -Receive: 27
Re: Bury Car Kit - RNS310
« Reply #1 on: October 11, 2014, 08:15:49 pm »
It's because the telephone mute connector on the RCD 300 it originally had was in a different location in the Quadlock, so that wire needs to be swapped/ spliced over.
RCD:
RNS:
Offline akbarirfan
  • -Given: 81
« Reply #2 on: October 11, 2014, 09:42:55 pm »
Oh right ok thanks - does that mean it is possible to make it work? I can't discover the Bury via bluetooth, is there something special I need to do?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #3 on: October 11, 2014, 10:05:22 pm »
I think it's probably because it's not a Bluetooth kit. You connect the handset to the cradle to physically make connection to the kit, rather than Bluetooth connectivity. The cradles are handset specific and (probably) no longer available as Bluetooth is more common these days.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #4 on: October 11, 2014, 10:07:04 pm »
That might not be correct of course, but just a possibility...
Offline J400uk
  • -Receive: 27
« Reply #5 on: October 12, 2014, 12:11:47 am »
It needs the cradle attached for it to be searchable via bluetooth, this bit http://www.amazon.co.uk/THB-Bury-Take-Talk-Cradle/dp/B000HHDLKC
Offline akbarirfan
  • -Given: 81
« Reply #6 on: October 12, 2014, 01:28:20 am »
Is that the same as the cradle in the glove box? Thanks
Offline J400uk
  • -Receive: 27
« Reply #7 on: October 12, 2014, 08:30:14 am »
Yep that's it
