Author Topic: Golf mk6 TSI - Battery went flat, now will not start  (Read 4480 times)
Offline rickyquicky
Re: Golf mk6 TSI - Battery went flat, now will not start
« Reply #15 on: October 21, 2014, 08:55:44 am »
It's a 2011.
If it does turn out to be the ECU, can a used one be programmed using vag-com?
Offline Eniqmatic
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,84578
« Reply #16 on: October 21, 2014, 01:30:33 pm »
You would need to match the ECU to the keys and Cluster at the very minimum for it to work, there may be more in that new a car. Will also be a tricore ECU so possibly a bit harder. I have a bench cable for use with VCDS if that helps at all? Would mean removing the ECU though.
