Author Topic: how the chuff to ya remove the drivers side footwell light?  (Read 4391 times)
Offline GTi-Andy
« on: October 13, 2014, 01:38:22 pm »
It so bloody tight down there, I can get to it properly.
So whats the best tool/way to do it
Im replacing all my interior lights LEDS and this is the last one to do and its being a real pain to remove
Ta in advance
Andy
So much for keeping it standard!
Offline Dave J
  • -Given: 45
  • -Receive: 63
Re: how the chuff to ya remove the drivers side footwell light?
« Reply #1 on: October 13, 2014, 08:20:08 pm »
I know what you mean - I found it difficult when fitting mine. I found that it was easiest to undo the panel that it's clipped into, then you can unclip the light from behind - far easier!
Edition 30 - no. 1387
Offline GTi-Andy
« Reply #2 on: October 13, 2014, 08:31:33 pm »
I thought about doing that too.
So just remove the screws and the panel drops down?
Cheers!
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #3 on: October 13, 2014, 10:02:13 pm »
Yep, that's right - from memory, it's just a few torx bolts and the panel can be dropped down.
Well worth it - LED lights sure give a nice fresh light to the interior
Offline GTi-Andy
« Reply #4 on: October 13, 2014, 10:10:02 pm »
Cheers Dave!
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #5 on: October 14, 2014, 12:20:30 pm »
I've just done the whole car in an hour, took more time to take all the pics than to fit them
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline GTi-Andy
« Reply #6 on: October 14, 2014, 01:32:39 pm »
@demon666 Damo, did you drop the panel too on the driver side footwell to get to the footwell light?
Offline boardyuk
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,88307.0.html
« Reply #7 on: October 14, 2014, 02:05:50 pm »
Had to drop the panel on mine too. Got the holder popped out without too much hassle, but had next to no slack on the cable going to it so couldn't actually remove the holder enough to get the plug out.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #8 on: October 14, 2014, 02:13:14 pm »
I heard all of this talk to about it being difficult to remove. Got mine easy, I wonder if each car differs.
Think about it this way, it's the same fitting as the glovebox. Was that not easy for you?
Get a small flat blade screwdriver behind the small lip on the light. There's a small rectangle removed to signify this side.
Twist the screwdriver and it will pop out easy!!
Offline DamoP
  • -Receive: 115
« Reply #9 on: October 14, 2014, 02:19:35 pm »
Just put a screw driver behind it and it came out
Saintsteve
« Reply #10 on: October 14, 2014, 03:44:40 pm »
Same here  :happy2:
Offline DamoP
  • -Receive: 115
« Reply #11 on: October 14, 2014, 07:01:13 pm »
