Author Topic: Wheel bearing  (Read 1049 times)
Offline dan930
  • -Receive: 56
Wheel bearing
« on: October 13, 2014, 11:24:19 pm »
A very stupid question for you all...I'm getting steering wheel vibration when braking from 50mph & when turning at speeds of 80+ on the motorway,also get a weird humming noise between 60-70 & 80-85(steering wheel vibrates a little too when I get the noise)any chance it be the wheel bearing
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Re: Wheel bearing
« Reply #1 on: October 13, 2014, 11:32:37 pm »
Got front wheel spacers?
dansmith180
Re: Wheel bearing
« Reply #2 on: October 13, 2014, 11:59:17 pm »
if there's some vibration under braking then it might be a warped disc? wheel bearing is normally just noise or if really bad a constant vibration (in my experience). I assume your wheels are balanced properly, tyre pressures correct and no spacers or spigot rings or wobble bolts?
Offline dan930
  • -Receive: 56
Re: Wheel bearing
« Reply #3 on: October 14, 2014, 12:02:50 am »
I've got 4mm spacers with hub extenders...wheels are balanced..
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline doylebros
Re: Wheel bearing
« Reply #4 on: October 14, 2014, 06:19:38 pm »
I would check the wheel nuts and hub nut for tightness incase anything is loose!
Then it's a case of systematically working through various items as suggested in previous posts.
