Author Topic: Talk to me about highline clocks/cluster  (Read 3496 times)
Offline GTi-Andy
« on: October 14, 2014, 09:49:25 am »
Hi All
I'm new to the VW scene and I've seen a lot of threads about highline clocks
Can someone explain what the differences are between the type of clocks available and which is the latest model highline that I should be looking at in installing in my 2007 GTi?
cheers
So much for keeping it standard!
Offline bbfb10
Re: Talk to me about highline clocks/cluster
« Reply #1 on: October 14, 2014, 10:13:19 am »
You need to know what model clocks youre running at the minute. A scan can tell you this, or take your clocks out and read the sticker on the back.
« Last Edit: October 14, 2014, 02:24:34 pm by bbfb10 »
Full VCDS Hex + Can.
Offline GTi-Andy
« Reply #2 on: October 14, 2014, 04:24:00 pm »
so this is the version of clocks that I currently have
1k6920962
Which highline clocks do I need?
Ta
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: October 14, 2014, 04:30:30 pm »
1k6920962
Ta
any ending in 970 971 972 973 974.
970 971 and 972 can be easily coded using vag commander, 973 and 974 is a bit different.
Multi function steering wheels only work with 973 and 974.
Offline GTi-Andy
« Reply #4 on: October 14, 2014, 04:32:45 pm »
1k6920962
Ta
Okey dokey, so as I have the multifunction steering wheel I will require a set of clocks ending in either 973 or 974?
Offline usmangti
« Reply #5 on: October 14, 2014, 04:34:45 pm »
1k6920962
Ta
Not true that bud, I have a MFSW with a 960D speedo and everything works properly.
To the OP 970, 971 or 972 are the easiest to code. I would go for that. other than that I am 99% confident the speedos are all the same. Just different years have different model numbers
Offline GTi-Andy
« Reply #6 on: October 14, 2014, 04:45:22 pm »
AAAARRRGGGHHH, brain freeze - who's right???  :rolleye: :rolleye: :rolleye:
just need a definite answer please guys
this is what I've currently got
2007 GTi with MFSW, current clock number 1k6920962
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: October 14, 2014, 04:53:41 pm »
1k6920962
Ta
Have you got the older or newer style mfsw?
Offline usmangti
« Reply #8 on: October 14, 2014, 04:55:44 pm »
Newer style ie I have menu buttons to access menus in speedo.
@GTi-Andy check my previous posts there is loads of info there and some pics too  :happy2:
Offline GTi-Andy
« Reply #9 on: October 14, 2014, 05:33:42 pm »
Mine can access the menus in the speedo using the right hand side buttons.
Offline Tim62
« Reply #10 on: October 14, 2014, 09:32:01 pm »
Another one here with mfsw: had 962 midline clocks, now 972 highline and buttons work fine. That said, mine's 2005 so I don't know if the mfsw or controller changed by 2007?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #11 on: October 14, 2014, 10:58:25 pm »
That's strange? When I put my mfsw on my old golf it didn't work,  had to change it to a  973 clock and it worked.
Offline usmangti
« Reply #12 on: October 14, 2014, 11:52:38 pm »
Must have been another reason perhaps.
Just realised above I only referenced my old speedo which was a 960. I had the upgraded to  a 972, which is regarded as an early speedo.
Also I'm pretty sure there are no other differences in terms of speedo other than you need a specific VAG commander cable to access the SKC codes on later speedos ending 3 or 4. Whether midline or highline.
