Author Topic: Latest PCV  (Read 1435 times)
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Latest PCV
« on: October 14, 2014, 05:07:18 pm »
Latest Revision is R. Has anyone fitted this? Are there issues with check valves as per Revision P?
'07 Red manual
Shaunygti
Re: Latest PCV
« Reply #1 on: October 14, 2014, 07:19:06 pm »
Fitted one month or so ago been all good
Offline akbarirfan
  • -Given: 81
Re: Latest PCV
« Reply #2 on: October 15, 2014, 10:37:42 am »
Shaungti - did you install a new gasket too? or just the valve?
Offline akbarirfan
  • -Given: 81
Re: Latest PCV
« Reply #3 on: October 15, 2014, 02:34:59 pm »
Is it worth changing from N to R?
I believe I would need a new pipe with a check valve in too if I was to upgrade.
(BWA engine)
Shaunygti
Re: Latest PCV
« Reply #4 on: October 18, 2014, 08:19:30 pm »
No gasket was all good so didn't bother just replaced one hose as split. :happy2:
