Author Topic: V9 Map Disc With Speed Cameras  (Read 8974 times)
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
Re: V9 Map Disc With Speed Cameras
« Reply #15 on: October 19, 2014, 09:21:05 pm »
From holding down the set up button, I have the hidden menu enabled
Instagram @george_kersh
Offline Georrge
« Reply #16 on: October 20, 2014, 10:57:31 pm »
It just seems as if my SW version doesn't match up with what is actually installed   :confused:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #17 on: October 21, 2014, 12:29:47 am »
Upgrade your version and get your problem solved (except the battery drain issue, that you need to test to see if the fix works for you).
Just use a modified update version (and not a factory version that deletes you coding) and you won't need to code your unit with VCDS. That's what I've been doing and never needed to code mine. :wink:
Offline Orc
  • -Receive: 25
« Reply #18 on: October 21, 2014, 07:47:25 am »
Can somebody do a update disc for my rns it has old software on there I believe and I'm not that great at downloading the right stuff myself.
Offline Georrge
« Reply #19 on: October 21, 2014, 09:58:21 am »
Easier said than done when all the links for the firmware come back with 'file not found' because the links are so old  :confused:
I need modified versions of 1100, 2680, 3810 and 3970. I've been told I can't just jump from 0900 to 3970. I've spent a while looking and come across loads of old forum threads on the topic, but every single link is broken  :sad1:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #20 on: October 21, 2014, 10:44:53 am »
You can safely jump to modified 3810. :wink:
Your unit will be completely formatted so I don't see the benefit of doing those older firmwares.
Offline skard
  • -Receive: 245
« Reply #21 on: October 21, 2014, 10:51:37 am »
http://rnsfirmware.com/downloads/RNS510_Firmware/Europe/EU_4020a_FW_60_35_5.ISO
This has the new partitioning which is necessary to put v10/11 maps on units with a 30GB HDD.
You'll need to put maps, POI and all music back on.
I have this FW on my A unit by the way.
Offline Georrge
« Reply #22 on: October 21, 2014, 11:21:48 am »
I'll take your word for it then :happy2: I was jsut purely going by what vRS Carl told me, this will be the first time updating my firmware so I'm literally just taking into account what others are telling me. But you amongst others have said it will be fine, so I'll go ahead and get it done!
Cheers for the link buddy! I am downloading now and will update this afternoon. Does it lag at all, or does it all run smoothly?
IF MY UNIT GETS BRICKED I WILL BE RUNNING A COLLECTION OF £50 FROM EVERYONE WHO CONTRIBUTED  :signLOL: :signLOL:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #23 on: October 21, 2014, 11:38:49 am »
The firmware update is done with the ignition off. So don't put the key in the ignition. :wink:
Offline skard
  • -Receive: 245
« Reply #24 on: October 21, 2014, 11:45:30 am »
I have only ever had my A unit but it is no slower than any aftermarket stereo I have used
Offline Georrge
« Reply #25 on: October 21, 2014, 12:14:28 pm »
The key will remain out, cheers!
Just popped down to staples to spend £13 on a pack of blank discs.. funnily enough they had sold out of single discs..  :signLOL:
Time to burn it to disc!
Offline Georrge
« Reply #26 on: October 21, 2014, 01:45:42 pm »
Update complete, seems to be running faster than it was originally :signLOL:
When will I know if I have the battery drain issue? Will it be dead in a few hours, or is it an overnight thing? Or should I just assume I have the issue and do the fix for it? I don't fancy getting stuck at work tomorrow :signLOL:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #27 on: October 21, 2014, 01:58:14 pm »
Depends on how your battery is atm. It can be hours or days. :signLOL:
I would do the fix and have some jumper cables at hand... :scared:
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #28 on: October 21, 2014, 02:06:34 pm »
You should fix the battery drain. And next time I tell you to do something......
You may now install the new maps disc you have. :happy2:
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline Georrge
« Reply #29 on: October 21, 2014, 02:39:55 pm »
I'll run the fix just in case then! All seems well, but my bluetooth module seems inactive?
Also, am I right in thinking that I should now have the feature which displays what song is being played over the Radio?
Viking, that disc got chucked :signLOL: But now I updated I'm able to add them myself via the memory card  :laugh:
