Author Topic: V9 Map Disc With Speed Cameras  (Read 8955 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: V9 Map Disc With Speed Cameras
« Reply #30 on: October 21, 2014, 02:43:36 pm »
Yeah, radio text available with fw 4020.
Not sure about your Bluetooth module. I don't have one. Viking should be able to help you.
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
« Reply #31 on: October 21, 2014, 02:47:28 pm »
Awesome, is it automatic or do I have to enable it somewhere? Just had a quick test but it simply just displayed the Station name.
I'm hoping it will just start working haha, if it doesn't work by tomorrow I'll shout for help  :signLOL:
Instagram @george_kersh
Offline skard
  • -Receive: 245
« Reply #32 on: October 21, 2014, 03:14:37 pm »
Radio text starts at 4120.
Personally, I would just update the gateway. They aren't expensive these days.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #33 on: October 21, 2014, 03:19:06 pm »
Oh, sorry for the mistake. It has been long time since I've checked the features of the firmwares.
Upgrade to 4120 modified and you'll have the option to activate radio text in the Radio Extras button.
Offline Georrge
« Reply #34 on: October 21, 2014, 03:28:21 pm »
Ah I see, I'll just go without it then I think considering I've only just updated to 4020 :signLOL:
My gateway may have already been updated when the previous owner put the RNS 510 in, I don't know. But just to be on the safe side I'll do the software fix, if it's a fix it's a fix  :smiley:
Cheers for all the input
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #35 on: October 21, 2014, 04:36:03 pm »
If you check the part number we'll know if the CAN is new. :wink:
Offline Georrge
« Reply #36 on: October 21, 2014, 05:10:37 pm »
*NOOB ALERT* where do I find the CAN?  :signLOL:
I just tried installing the fix for it but was displayed with this message:
I was tempted to press the 3 buttons then try again, but thought I'd ask just in case haha. On a plus side, my bluetooth is up and running again :laugh:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #37 on: October 21, 2014, 05:16:17 pm »
It's normal. Just follow the instructions. :wink:
I didn't know until someone explained in another topic but the CAN changed position, so it depends on the year your Golf was made.
Here's a vid:
Offline Georrge
« Reply #38 on: October 21, 2014, 05:37:52 pm »
So I press the 3 buttons and away I go? Sorry for all the daft questions, just the thought of bricking my unit hurts :signLOL:
I'll leave that as a last resort, the software fix seems a lot easier, quicker and cheaper :happy2:
Offline Georrge
« Reply #39 on: October 22, 2014, 07:25:22 pm »
Done the canbus fix, made some weird noises through my speakers at random points but all is well  :signLOL:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #40 on: October 22, 2014, 07:50:28 pm »
Nice! :happy2:
Offline Georrge
« Reply #41 on: October 24, 2014, 10:26:32 pm »
Right, since doing the canbus software fix, my media hasn't worked.
Pressing the 'Media' button gives the message 'no medium available'. I can still connect my phone via bluetooth, but can't stream, can't access my memory card, or the rns harddrive.
Any suggestions?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #42 on: October 24, 2014, 11:57:26 pm »
Check your CAN Gateway part number.  :wink:
Update it if needed and update your firmware without worries.
Offline Georrge
« Reply #43 on: October 25, 2014, 05:50:33 pm »
My firmware is updated, but now my media doesn't work. It just says 'no medium available'. Surly that wont be due to my CAN gateway?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #44 on: October 25, 2014, 06:20:44 pm »
When you used the CAN gateway fix you downgraded some files of your firmware so it wouldn't drain your battery if you have an old CAN gateway. Now you need to re-install the new firmware if you want your RNS-510 to work 100%.
If you update the firmware and your CAN is old, you'll have the battery drain issue.
Hence, check if you need to update your CAN. If it's new enough, you don't need the fix. If it's old, you need to get a new one to not have any problems with the new firmwares.
