Author Topic: Cruise Control Retrofit  (Read 1820 times)
Offline Riz_mkv
« on: October 18, 2014, 03:02:09 pm »
Just fitted cruise control on to my car and tried to code it, however on VCDs in Engine "Coding ii" will not allow me to select it and under fault code it comes up with Error P0568 - Cruise Control Switch (E45): Implausible Signal
Can anyone help me as to why this is happening
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Cruise Control Retrofit
« Reply #1 on: October 18, 2014, 03:04:25 pm »
Was the cruise control wire fitted?
Offline Riz_mkv
« Reply #2 on: October 18, 2014, 03:16:47 pm »
I wasn't provided with any wires just the cruise control stalk as I believe that's all I needed and some coding :/
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: October 18, 2014, 03:22:47 pm »
What year is your golf?  I think 2006 onwards came with the wire fitted from factory
Offline Riz_mkv
« Reply #4 on: October 18, 2014, 03:31:07 pm »
Yeah my car is 2006
Offline tfsi_syncro
« Reply #5 on: October 27, 2014, 01:26:29 pm »
You may have to change the steering wheel control module depending on what variant you currently have. When you run a scan in VCDS you should be able to see which one is currently in your car.
Also bare in mind that you will need to make sure you select one that is compatible with your slip ring.
Use the link below to determine which one you will need or to confirm that you already have the correct one in place.
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
