Author Topic: GTI Sideskirts  (Read 1159 times)
Offline JimmyC92
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,88339.msg896687.html#msg896687
GTI Sideskirts
« on: October 20, 2014, 07:44:03 am »
Been looking around for a pair, I have found a replica set on the bay however they seem pretty hard to come bye, anyone bought some before and could recommend? Also how are they fitted?
Looking for some BBS CH/LM Reps to swap for my Classix plus cash your way:
http://www.mk5golfgti.co.uk/forum/index.php/topic,91888.msg924311.html#msg924311
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: GTI Sideskirts
« Reply #1 on: October 20, 2014, 08:49:36 am »
Best to go to a VW dealer. They're cheaper than ebay. Fitting with screws and bonding tape.
'07 Red manual
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: GTI Sideskirts
« Reply #2 on: October 20, 2014, 09:02:21 am »
Scrap yard, front end collision car with no damage to skirts would be about 30 each. Remove them with a hairdryer to loosen the double sided tape and some strong floss or thin string.
Or if you're feeling lazy (most likely what I would do) go to VW. Ask them about the correct double sided tape, too thick and they won't sit flush and they'll also allow water ingress in between panel leading to rusting down the line.
On a side note, while they're off the car have them colour coded!
Offline Dave7692
Re: GTI Sideskirts
« Reply #3 on: October 20, 2014, 09:47:04 am »
The genuine black non-colour coded ones from VW/TPS are under £90 for the pair, I picked a set up a few weeks ago and then had them smoothed and painted for £70 a side, fairly expensive all in all but still cheaper than buying pre-smoothed ones from VW/TPS.
Personally I think you're best going genuine as if they don't quite fit right they'll trap a lot of water/muck over time and could cause issues further down the line.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: GTI Sideskirts
« Reply #4 on: October 20, 2014, 09:50:56 am »
Use Fishing Nylon, excellent for removing anything stuck on, especially good at badges.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: GTI Sideskirts
« Reply #5 on: October 20, 2014, 11:59:29 am »
They come pre-taped.
'07 Red manual
Offline JimmyC92
Re: GTI Sideskirts
« Reply #6 on: October 20, 2014, 01:38:16 pm »
Thank you very much guys!
Offline basman
Re: GTI Sideskirts
« Reply #7 on: October 22, 2014, 12:41:13 am »
This is the best way also you need the fitting kit it's mad the edition 30 ones are like 250 each and black ones from tps are roughly 40 each
Offline andybon
Re: GTI Sideskirts
« Reply #8 on: March 10, 2015, 11:20:52 pm »
Just out of intrest, how are these fitted, are they just bonded or do you need any fittings for them?
How hard can it be?
