Author Topic: Morgens ED30 No. 1871 - New suspension & audio!  (Read 137286 times)
Offline wazza16
Re: My ED30 No. 1871!
« Reply #210 on: February 24, 2016, 05:34:54 pm »
Nice example.. theres quite a few ED30 owners up in scotland!
Offline Morgen
  • 2008 DSG Edition 30
« Reply #211 on: March 08, 2016, 04:43:32 pm »
Thank you!
I've noticed this too, haha.
That's my CV joints FINALLY done... Though only one side! The passenger side only needed a boot so I've saved myself £40  :grin:
However, I have a puncture so that £40 is now going towards yet another tyre  :sad1:
Offline alex55
« Reply #212 on: March 11, 2016, 11:34:48 pm »
looking good, steel grey is the best colour
Offline Morgen
« Reply #213 on: April 01, 2016, 05:11:37 pm »
Okay, so nothing exciting has happened since my last post, because I'm skint as per usual.
Booked my car into my work for a major service - this could have been done myself but I couldn't be bothered finding out how to turn the light out and I wanted a stamp in my book as the last "official" service was exactly a year previous  :smiley:
They changed the oil and plugs etc, but couldn't check the car over as it's too low to get on our ramps! They sent her to the garage just down the road and they reported back that I need new front discs & pads, that I'm missing a backing plate from the nsr disc and that the long drive-shaft is rubbing on the anti-roll bar. I mentioned this to Adam and he persisted that it couldn't be.. Jacked the car up, had a look and it's not rubbing! The mind boggles. I am however watching some R32 calipers, discs and pads on ebay that are in my area. Very tempted!
I have another very very VERY VERY VERY annoying issue:
When driving at 50mph+ I start getting a horrendous vibration through the steering. At around 60-70mph it's so violent that the arm rest can actually be felt juddering from side to side and the steering wheel is quite difficult to hold comfortably. The car first did this back in September 2015 after receiving it back from a garage (was in for 2 rear control arms and a full alignment) and I assumed it was a wheel balancing issue so in October the wheels were finally balanced and the problem was still there. I took the car back to the garage that did the initial work and they checked it over... On the phone they said it sounds like a driveshaft problem so that's the first thing they checked. Absolutely no play in either shaft, and all the suspension appears sound. They suggested I raise the car as it was stupidly low, and this should eliminate my issue somewhat. I raised the car a few days later and they were correct, problem resolved to a standard I was comfortable with. However, it's back with a vengeance  :sick:
I don't know what to do - there's still absolutely no play in either shaft! I don't want to go replacing them and it turns out to be something else, but no garage has been able to pinpoint anything at all wrong with the car.
People have suggested the tyres but both fronts are brand new and have been changed during the time period this problem has occurred.
The wheels being buckled has been another suggestion, so I'm going to swap the front wheels to the back to eliminate that option.
Has anybody else had this problem? I'm trying to get to the bottom of it with no luck! The cars DSG and driveshafts aren't friendly priced so I'd rather not replace them to find out they weren't ever the issue  :confused: HELP HELP HELP!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=a7e8hjnqdu68qoth4go8mpoh0t&/topic,19740.0.html
« Reply #214 on: April 01, 2016, 05:19:33 pm »
Have you had the wheel balance checked?
Offline Morgen
« Reply #215 on: April 01, 2016, 06:24:30 pm »
To be honest I haven't. When I let off the acceleration the judder is worsened which makes me think driveshaft :(
« Reply #216 on: April 01, 2016, 06:28:47 pm »
Worth getting them balanced... Its quick and cheap to do, just to rule that out.
Offline Namsgti
« Reply #217 on: April 01, 2016, 06:40:17 pm »
Maybe worth checking drive shaft rubbers split
Offline Morgen
« Reply #218 on: April 01, 2016, 07:00:19 pm »
They were balanced in october after the issue first started and made no change :( I'll get it re-done to further rule it out though!
Offline Morgen
« Reply #219 on: April 01, 2016, 07:01:14 pm »
The boots had split on the outer cv joints, but one boot was replaced and the cv joint on the other side was totally replaced too
Offline th3_f15t
  • -Receive: 183
« Reply #220 on: April 01, 2016, 07:36:43 pm »
Tracking been done?
Checked your tie rod ends, drop links and all the bushings?
Wheels mounted properly (spigot rings where required) and bolted to 120nm?
Steering rack been checked over?
Does the issue go away under braking? If so, could the discs be massively worn/warped?
Just my 10p, hopefully you'll find the cause soon enough.
Offline GTI-MATT
  • GTI-MATT
« Reply #221 on: April 01, 2016, 08:22:22 pm »
Could be a front brake caliper binding on. I had it on a astra in work when you accelerate it pushes through the brake and you dont notice it so much but when you shut off you notice it more and get the vibration through the steering wheel. Jack it up and check the front wheels turn free by hand when in neutral. Usually gets worse when the brakes are hot due to expansion :happy2:
Offline th3_f15t
  • -Receive: 183
« Reply #222 on: April 02, 2016, 05:42:06 pm »
Nice, something else to add to the knowledge base. I'm assuming with a worn/warped front disc the problem will be exaggerated?
Offline Morgen
« Reply #223 on: April 04, 2016, 03:36:25 pm »
Thanks! I'll try this one tonight  :happy2:
Hopefully that's the issue - as the front caliper did stick a few months ago! I'm watching brakes on ebay too so if that's the issue it's an easy fix  :grin:
Offline omeydz
  • -Receive: 50
Re: Morgens (currently broken) ED30 No. 1871!
« Reply #224 on: April 04, 2016, 03:57:55 pm »
Hope you find a fix soon Morgen! Good luck  :smiley:
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
