Author Topic: Will this Cruise control - Part Number: 1K0953513G work?  (Read 5033 times)
Offline edition30jmr
  • ED30
« on: October 25, 2014, 07:24:36 pm »
Hi guys will this cruise control stalk work with my edition 30 I have a multifunctional steering wheel I plan to fit at the same time! Just wondered if this (OEM Part Number - 1K0 953 513 G) version would work with the new mfsw etc?
Jay
Ed30 Beast!
Offline skard
  • -Receive: 245
Re: Will this Cruise control - Part Number: 1K0953513G work?
« Reply #1 on: October 25, 2014, 07:37:22 pm »
Yes it'll work fine.
Cruise works without MFSW too, but check what steering wheel control module you are fitting, as some don't like retrofitted cruise, not many of them are iffy but they exist.
  • ED30
« Reply #2 on: October 25, 2014, 07:40:24 pm »
Thanks, the module I'm planning on fitting is 1K0953549BK
Would this work okay?
Thanks :happy2:
Ed30 Beast!
Offline skard
  • -Receive: 245
  • ED30
« Reply #4 on: October 25, 2014, 07:54:17 pm »
Yes BK should be fine.
See here too http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
What other modules could I use to work with the new MFSW? (Currently non MFSW)
Ed30 Beast!
Offline skard
  • -Receive: 245
« Reply #5 on: October 25, 2014, 07:55:32 pm »
The ones on that list that say highline, stick with type 2 as that's what most mk5 sliprings are
  • ED30
« Reply #6 on: October 25, 2014, 07:56:21 pm »
Would I need a new slip ring too? Or can the current one be used? Thanks again!
Ed30 Beast!
Offline skard
  • -Receive: 245
« Reply #7 on: October 25, 2014, 07:57:50 pm »
You have to physically check, or use your existing SWCM part number and compare it to that list to see what type it is
  • ED30
« Reply #8 on: October 25, 2014, 08:07:35 pm »
Okay thanks am I right in thinking that this would work okay with the MFSW and cruise stalk? 1K0 953 549 CH (removed from a 2010 1.4 tsi golf)
Thanks :drinking:
Ed30 Beast!
Offline skard
  • -Receive: 245
« Reply #9 on: October 25, 2014, 08:10:49 pm »
According to that table, I would say so. But make sure you get the G stalk, and not the older A stalk (they have different symbols on, easy to differentiate)
  • ED30
« Reply #10 on: October 25, 2014, 08:30:16 pm »
Yes it would be a G stalk! All sounds good to go, thanks for your help, do you know if the buttons on the new MFSW will work with a headunit: kenwood dnx521dab? (The ones Vw use now)?
Ed30 Beast!
abdulk79
« Reply #11 on: March 13, 2016, 07:05:03 pm »
Hi,
Sorry to open this old tread.. Just wanted to know 1K0 953 549 CH controller worked with your 1K0953513G stalk.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: March 14, 2016, 08:57:53 am »
Hi,
Yes they would.  I have the exact same setup.
Sent from my SM-G928F using Tapatalk
