Author Topic: can the sidelights work via the auto headlight switch  (Read 1780 times)
Offline Rob1
  • -Given: 40
  • -Receive: 24
« on: October 26, 2014, 11:44:05 am »
Hi just enquiring if it is possible to change which lights work via the auto lights set up, I.e. could vcds enable the side lights to work in auto mode as opposed to the headlights?
Thanks rob1
Black Ed30
Offline KieranED30
  • Burning Rubber Since 16th Febuary 2012
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89941.0.html
Re: can the sidelights work via the auto headlight switch
« Reply #1 on: October 26, 2014, 12:44:41 pm »
I was wondering this too becaus as soon as it goes dull side light and headlight come on auto it should be in stages, side lights first then when it gets darker headlights :)
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #2 on: October 26, 2014, 03:24:46 pm »
Yep does the same, well the headlights come on. I am considering fitting led bulbs as the sidelights hence the question.
Black Ed30
Offline KieranED30
« Reply #3 on: October 26, 2014, 03:35:20 pm »
I have got led ones in anyway :) 6000k bright white :)
Offline xjay1337
  • -Receive: 377
« Reply #4 on: October 26, 2014, 04:59:20 pm »
Thanks rob1
No.
Dipped beam and side lights only.
Why would you want sidelights on anyway? You can't use them for visibility at all! Only being seen, in which case dipped beam would be better all around, no?
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #5 on: October 27, 2014, 05:19:58 am »
Hi, similiar question, if I replace the fogs with DRL's would it be possible to have them turn off with the the Auto lights? Or how could I have them setup?
