Author Topic: I can't decide - Power or looks?  (Read 2915 times)
Offline bluo
Re: I can't decide - Power or looks?
« Reply #15 on: October 28, 2014, 09:19:59 am »
Once you pop you can't stop - doesn't matter which one you do first because you'll almost certainly do the other soon after!!!
Good luck with the modding bug, there's no cure!
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #16 on: October 28, 2014, 11:03:50 am »
Tell me about it I only planned on remapping or lowering springs on the Pirelli and now after a Google and reading threads over the last day or two on here I now want: (this site is deadly and expensive)
BCS Powervalve/non-res milltek full system
R32 front brakes
B12 suspension  :driver: :signLOL: so much for just lowering springs!
15mm rear spacers
Helix organic clutch.
P-flo induction kit/maybe pipercross as done want to loss low down torque
R-tech tuned!
I'm gonna need to put some more hours in!
 :jumpmove: :signLOL: :driver: :happy2:
GTI Pirelli - Reflex Silver - 5dr - 58 - B12 Sportline kit!
Sold ~ GTI - Mk5 - Pearl Black -  Bluefin - 3dr - 08
Offline th3_f15t
  • -Receive: 183
« Reply #17 on: October 28, 2014, 12:15:29 pm »
I'd say before buying an induction kit, just get an air filter (K&N or Pipercross) as at stage 1 there's little point in an induction kit. I've had good results from using the standard air box with a filter. This will then save a few quid which can go towards a full turbo back exhaust which sounds better and gives much better gains per pound spent.
It's very easy to fall into the "I NEED EVERYTHING!!!" trap when sitting on the web for a few hours, but a few days off the forums helps relax the temptation side of the mind.
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #18 on: October 28, 2014, 12:48:03 pm »
I see your point, I've been really quiet at work this week and spend a lot of time on the forum and thinking I need everything NOW!!! :signLOL:
I had a pipercross panel filter on my old Bluefin'd GTI and that made a nice quiet noise at low revs, like u said may be an idea to go with one again, but I was just looking for a little more noise really - my Bluefin'd GTI felt really rapid with great low down grunt and was really impress so I'm sure if I can get to the 300hp mark with just a panel filter and custom map I'm sure I'll be over the moon......and if I feel the need over time save up and get a cat back for more noise and pretty tail pipes then the full system, if the clutch lasts that long!
This is going to a slippery slope!
Offline bluo
« Reply #19 on: October 28, 2014, 01:00:00 pm »
I have a set of r32 brake calipers, discs and pads going for sale shortly... Finished in red to match OE colour.
I've had them for 5k so they're spotless - interested? PM me.
Offline hum3
« Reply #20 on: October 29, 2014, 01:52:15 am »
Power :driver:
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #21 on: October 29, 2014, 05:55:20 am »
