Author Topic: KO4 Upgrade kit  (Read 1538 times)
Offline mvb12
  • -Receive: 64
KO4 Upgrade kit
« on: October 27, 2014, 01:46:10 pm »
So just gathering a few bits and got the following question.
Do KO3 owners not have any of the gaskets at all?
N 044 502 3 - has this PN been changed as it doesn't seem to come up on the system.
06F 145 757 F - is this meant to be 3 different gaskets as the shapes are different but the system only shows 1 gasket included for the part number.
http://i1253.photobucket.com/albums/hh598/mvbrands/k04kit.jpg
Any help would be appreciated
Re: KO4 Upgrade kit
« Reply #1 on: October 27, 2014, 02:42:18 pm »
N 044 502 3 is an exhaust stud and should be N0445203 (M10X28)
06F145757F is a metal gasket and you should only need one for between the rear pvc breather hose and the turbo.
Offline mvb12
  • -Receive: 64
Re: KO4 Upgrade kit
« Reply #2 on: October 27, 2014, 03:02:01 pm »
you the man  :happy2:
Minus the S3 Injectors, is there any other part which shows more than 1 that I actually only need the 1?
Offline th3_f15t
  • -Receive: 183
Re: KO4 Upgrade kit
« Reply #3 on: October 27, 2014, 08:52:01 pm »
This may be a stupid question, but do you need to run a thicker head gasket when converting a BWA/AXX engine to a K04 as I thought the larger turbo engines had lower compression in the cylinders..? Or am I getting it muddled up with something else?
