Author Topic: Throttle body swap, plug and play?  (Read 1552 times)
Offline JimGTI
« on: October 27, 2014, 02:48:04 pm »
Need a definitive answer on this, will be swapping out the throttle body on my 06 GTI for a revision Q TB that I have bought, is it just a straight swap with no further action needed in VAGCOM? I have heard conflicting stories that if you swap the TB it will need calibrating via VCDS. Other sources say it will self calibrate. Just want to know before I swap it over.
Jim.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Throttle body swap, plug and play?
« Reply #1 on: October 27, 2014, 03:13:47 pm »
Mine was fine without VCDS... swap it out and take it for a drive... but I know there is a realign procedure in VCDS.
Offline JimGTI
« Reply #2 on: October 27, 2014, 03:20:34 pm »
No problem I am going to swap it tonight. Is it easily accessible?
Cheers.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #3 on: October 27, 2014, 04:37:14 pm »
Cheers.
No, it's fiddly and cramped - but I do have sausages for fingers... curse my sausage fingers : P
Offline JimGTI
« Reply #4 on: October 27, 2014, 04:38:56 pm »
Thank you. Is it a couple of hoses then just the four hex bolts? Do I disconnect the battery first? Thank you for the help.
Jim.
