Author Topic: benchtest rcd310  (Read 2019 times)
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
benchtest rcd310
« on: October 27, 2014, 05:14:01 pm »
hi
does anyone know how to bench test a headunit,
more specifically what pins need powering and ground
 :smiley:
like this guy has done
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: benchtest rcd310
« Reply #1 on: October 27, 2014, 05:41:12 pm »
I guess you will need a spare wiring connector for the rear of the head unit, then run the relevant power wires to a battery or ideally a bench power supply.
Jas
VCDS (Preston, Lancashire)
Offline skard
  • -Receive: 245
« Reply #2 on: October 27, 2014, 06:07:18 pm »
Pins marked +UB and Code need 12v. Earth, needs an earth.
Offline DanMaytee
« Reply #3 on: October 27, 2014, 06:23:43 pm »
I've always used an old PC power supply :).  Actually used one as a stereo in the home for quite a while! :)
Offline reaper7881
« Reply #4 on: October 28, 2014, 12:19:52 pm »
Sorted
