Author Topic: SD Cards for RNS 510  (Read 1804 times)
Offline BenGTI
« on: October 28, 2014, 03:45:54 pm »
What SD cards actually work in the RNS 510 i have tried a few now and no luck what have you guys got ?
  • -Receive: 427
Re: SD Cards for RNS 510
« Reply #1 on: October 28, 2014, 04:02:51 pm »
IMO any good 32GB SDHC memory card will do the trick. I use a Sandisc Extreme Pro, costs around £30-£40 IIRC.
Offline BenGTI
« Reply #2 on: October 28, 2014, 04:27:20 pm »
Okay cheers, tried a sandisk before and it didn't work :/
« Reply #3 on: October 28, 2014, 04:33:15 pm »
What firmware version are you running as larger capacity sd cards may not be compatible with old firmware versions.
Offline Carpy25
« Reply #4 on: October 28, 2014, 04:54:58 pm »
I use 8 gb scandisc cards in my RDS 510 and on start up with SD card selected it takes about 30-40 seconds  to start playing seems much longer than that, I assume this is because the RDS is scanning the card ? so I'm glad I didn't go for a big card and went with four or five smaller ones as a big card could/should take far longer to scan on start up
Rob
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #5 on: October 28, 2014, 08:55:57 pm »
What bacillus said! :wink:
Try an old 2 Gb SD card, even with older firmwares it should work. If not, your card reader isn't working.
Offline BenGTI
« Reply #6 on: October 28, 2014, 09:48:04 pm »
Okay cheers! It does work as I had one before but can't remember what SD card it was I used to put it in my wallet but lost it... Someone handed it in but took the SD card haha
I'll have a look at the firmware on it tomorrow and hopefully someone could point me in the right direction then !  :happy2:
