Author Topic: Mk5 Gt tdi DSG jerking :(  (Read 2405 times)
Offline Tomm
« on: October 28, 2014, 04:58:26 pm »
Hey
I have a mk5 gt tdi dsg.  The car sometimes jerks a little bit when I’m driving. Also when the car is cold in the morning and i have it in drive whilst stationary at the lights the car jerks and sometimes cuts off, However when i put the car in neutral its fine. Its starting jerking a little bit when I’m driving even when the car has heated up. Something aint right :(
Does anyone know what this problem could be?
Offline doylebros
Re: Mk5 Gt tdi DSG jerking :(
« Reply #1 on: October 28, 2014, 05:21:01 pm »
An oil change and a reset would be a good starting point these post will help.
http://forums.tdiclub.com/showthread.php?t=169356&highlight=DSG+DIY
http://www.mk5golfgti.co.uk/forum/index.php/topic,24158.0.html
If those fail then it gets expensive!
Offline Tomm
« Reply #2 on: November 01, 2014, 10:41:49 pm »
Thanks! hope the reset works. What if the reset doesn't work, what do you think it could be ? worried !
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: November 01, 2014, 10:47:25 pm »
Maybe the DSG oil needs changing (Depending when it was last done)
If that doesnt solve it, then could be mechatronic unit on its way out
Offline Tomm
« Reply #4 on: November 01, 2014, 10:53:25 pm »
Forgot to mention, i had the dsg serviced quite recently. Il see if this reset helps
Offline AndyBrown
« Reply #5 on: November 01, 2014, 11:32:08 pm »
Vw can diagnose it for £65.
Offline Tomm
« Reply #6 on: November 03, 2014, 06:08:30 pm »
I'm going to reset the dsg and hope that will solve it , if it doesn't it will have to go to the dealers for a check.
