Author Topic: Key coding?  (Read 1369 times)
Offline mk4gti-t
  • -Given: 61
Key coding?
« on: October 28, 2014, 07:07:23 pm »
I currently only have 1 key that will start my car. I had a serious ecu failure and ended up swapping the ecu and clocks for a second hand set off ebay that got my car going. The set i got only had 1 transponder part that i swtched my remote and blade to. So ive got another key that will open the doors and go in the ignition but not get passed the immobiliser. Question is can i get this key coded to work so i have a good spare? Cheers.
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
Re: Key coding?
« Reply #1 on: October 28, 2014, 07:49:31 pm »
You can, I know vw charge around £180 for a new cut and coded key. There are some key specialist around who would be a hell of a lot cheaper
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Key coding?
« Reply #2 on: October 28, 2014, 08:37:36 pm »
You may need to get a blank transponder chip and then reprogram it. old keys cannot be reprogrammed again as the chip ( i think its called an RFID chip) can only be used once.
Offline sootpig
Re: Key coding?
« Reply #3 on: October 28, 2014, 08:48:33 pm »
« Last Edit: October 28, 2014, 08:53:28 pm by sootpig »
