Author Topic: Near side tilting mirror when reversing  (Read 5285 times)
Offline mortygttdi
  • -Receive: 146
Re: Near side tilting mirror when reversing
« Reply #15 on: November 15, 2009, 06:24:42 pm »
Yes sorted apart from 1 option that I carn't get right and that is the ATA confirm,  turn it to ON and the beeps will confirm when unlocking but wont confirm on locking??? every thing else works,
Also people saying xenons cannot be fitted on low spec central electronics boards,  Well I did Ollie288's the other day fitted the xenons and coded up and they work fine the coding takes although the bits are not there to tick? you can still mess with the binary coding and get it to work, The only thing you carn't do is activate the coding for shutters.
By the way you can get the mirror folding on reverse if you can find either one of these window regulator(controller) 1K0 959 702N Z93 or 5K0 959 702A Z1W
Darren
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #16 on: January 10, 2010, 09:34:58 pm »
In the long coding helper this was a tickable option on mine. I checked it and confirmed changes but it didn't work  :sad1:
What's the Comfort pack involve? I'm presuming from this I don't have it. Mine probably only has the Winter pack.
Pete
Offline Makaveli
« Reply #17 on: January 11, 2010, 08:02:47 pm »
Wasnt this feature only available on the later GTIs (2007 onwards?) and you also needed the folding mirrors etc (Lux Pack?) for it to work
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #18 on: January 11, 2010, 08:35:31 pm »
^ You're very likely right.
What does the Lux/Comfort pack actually include?
Pete
Offline Makaveli
« Reply #19 on: January 11, 2010, 08:58:22 pm »
This may help - http://www.scribd.com/doc/16287603/golf-2007 it gives details of the options
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #20 on: July 02, 2010, 04:15:03 pm »
Darren
Sorry to re-incarnate an old one, but turns out it's highly relevant - to this http://www.mk5golfgti.co.uk/forum/index.php/topic,16320.msg238472.html#msg238472
What's the difference in the two part numbers you quote please?
I'm suffering the well known window re-opening fault on closing and also VCDS confirms there are errors with the window mechanisms (I forget the exact issues but I'll re-check the log later).
If it is a regulator I need, which one would I need for my 2006 GTI?
Thanks  :drinking:
Pete
Offline golfman
  • -Given: 17
« Reply #21 on: July 02, 2010, 04:32:37 pm »
Dont know whether this would help or not!!!
http://furmanka.blogspot.com/2010/03/mk5-lusterka-mirrors.html
cheers
scott
Vag-com Hex+Can in scotland
I Hate Timewasters...
