Author Topic: Just fitted a new style cluster into a 2007 Golf GT  (Read 46335 times)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Just fitted a new style cluster into a 2007 Golf GT
« Reply #15 on: November 01, 2014, 08:14:53 am »
great mod Eddie  :happy2:
would this eliminate the error code with the newer mk6 climate panels the missing message one ?
I think it would, I've seen a scan of a 2004 golf which had a newer cluster fitted with a late BT mk6 climate panel and it didn't have the missing message fault.
Cluster and Key coding
Location Great Yarmouth
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #16 on: November 01, 2014, 08:17:25 am »
OH MY SWEET JESUS!  :surprised: :surprised: :surprised:
You sir are a legend!!! I need these in my car now! I have a 2005 GT TDI what will i need to change?
first you need to find out what ABS module you have
Just done a quick scan and my ABS is....
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl?
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0023170
   Shop #: WSC 00046 412 00000
   VCID: 3A7B2816759A24CE953-806F
Not sure what you wanted to know so I got everything...will this need changing and if so what to?  :innocent:
That one is too old
This one is ok 1K0 907 379 AC
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #17 on: November 01, 2014, 08:17:56 am »
A MY09 GT Sport 1.9 TDI has the following:
    Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
    Would it be compatible?
Yes[/list]
Offline Matto
  • -Receive: 116
« Reply #18 on: November 01, 2014, 10:50:28 am »
Nice work Ed. Was just thinking I have a MK6 highline cluster in the cupboard. Shame its a petrol version.
Offline skard
  • -Receive: 245
« Reply #19 on: November 01, 2014, 08:05:11 pm »
Don't, Ed. I already want the white clocks in the Tig as it is..!
Great work as usual.
you know you want colour ones
White ones bought for now  :party:
Offline xjay1337
  • -Receive: 377
« Reply #20 on: November 02, 2014, 01:12:59 am »
Eddie I did PM you but not sure if you got it
I want a (blue needle) R-Line TDI cluster on my Scirocco... It's the Mk6 one so already has a similar dash to the one in your retrofit.
Can you do it?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #21 on: November 02, 2014, 12:47:48 pm »
New or from ebay? Which part number did you go for?
Do you still have a tdi?
Jas
VCDS (Preston, Lancashire)
Offline skard
  • -Receive: 245
« Reply #22 on: November 02, 2014, 12:48:41 pm »
For my Tiguan
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #23 on: November 02, 2014, 01:40:00 pm »
Can you do it?
I can fit one, the hard job is finding one
Offline Timepillow
« Reply #24 on: November 02, 2014, 03:53:39 pm »
That one is too old
Thanks!  :happy2:
Is it hard to change? I know the ABS unit will need to be changed and properly some coding is involved but anything else?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #25 on: November 02, 2014, 04:24:22 pm »
That one is too old
Thanks!  :happy2:
Not that hard, coding will be the same. Bleed the brakes and do basic settings with vcds.
Offline Timepillow
« Reply #26 on: November 02, 2014, 05:34:33 pm »
Oh thats great then!  :happy2: :happy2:
Have you got a part number for the Clocks? I can't find any anywhere  :indifferent:
Offline skard
  • -Receive: 245
« Reply #27 on: November 08, 2014, 03:49:49 pm »
Ed coded my new Tiguan cluster and chips remotely. Gives the dash a much fresher look compared to the old red block, which I am increasingly growing bored of  :happy2:
Thanks once again Ed
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #28 on: November 08, 2014, 04:14:07 pm »
^ Nice.. I know what you mean about the All Red, it's a bit Dot Matrix in era - not something I'll be swapping this side of a different car though tbh.
Offline skard
  • -Receive: 245
« Reply #29 on: November 08, 2014, 04:22:52 pm »
Sadly I am still stuck with the red MFA in my Golf. Our last four cars have had the same ugly screen, might keep this one now, well until I find colour clocks!
