Author Topic: Horn! It sounds with the turn off the key but won't work off the wheel....  (Read 1349 times)
Offline Nickellis1
Hi guys I have a 07 mk5 gti 3dr. I removed the stock wheel and fitted an aftermarket omp wheel and boss. All was fine until
I removed the omp wheel and re-fitted my stock gti wheel, now everytime I turn the ignition to live the horns go off for about 3 seconds and stop. But the horns won't work off the steering wheel....
I have had the wheel off again and checked all the spade connections etc and all are ok, I have removed and re-fitted horns etc and made no difference at all.
I'm lost as what to try next any help would be greatly Appreciated.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Horn! It sounds with the turn off the key but won't work off the wheel....
« Reply #1 on: November 01, 2014, 04:38:10 pm »
Its possible steering wheel module needs recoding? Either that or check the airbag is seated correctly?
Any vcds errors?
Jas
VCDS (Preston, Lancashire)
Offline Nickellis1
« Reply #2 on: November 01, 2014, 04:58:07 pm »
The air bag is seated correctly as far as I am aware (sits flush) having it scanned on vag com tomorrow as the handheld I have isn't finding any fault
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #3 on: November 01, 2014, 06:44:43 pm »
When I fitted my mfsw the horn didn't work correctly until the coding was adjusted. Maybe it just needs re applying in vcds?
Jas
Offline Nickellis1
« Reply #4 on: November 01, 2014, 09:03:20 pm »
Where would I find the code to re-code it?
Thanks for your help
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #5 on: November 01, 2014, 10:28:00 pm »
In vcds steering control module. You see a code in the long coding section.
Vcds will tell you what each digit means so you can build up your code to put in the box.
Jas
