Author Topic: How to fit an Armrest  (Read 13756 times)
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« on: November 02, 2014, 10:41:19 pm »
How to Retro fit an Armrest into the MK5 Golf
T20 Bit + screw driver
Stubby T20 screwdriver
Small flat blade screwdriver
All the screw that are removed are T20 Torx screws. So only one screwdriver bit is required. I used 2 screwdrivers, if you can get a stubby it will really help.
This is a full leather mk5 Golf Armrest with the rear heater pipe
You will need to remove the standard hand brake/ cup holder. It has 2 screws under the circular rubber mat.
I would give all the parts a good clean now prior to fitment. I have used Simonz dashboard cleaner on all the plastics and Autoglym leather care cleaner on the top. And hover years worth of c**p under the plastic.
To save damage remove the hand brake Leather cover. A flat blade screwdriver locates under a flap and it slides off.
Bring the main casing over the handbrake. Then add the handbrake slider casing. A bit of lifting/man handling is required. Now add the heater pipe (if required) this takes some patience to locate.  You will now have to put the 3 screws on the handbrake slider casing, front back and left side
There are 4 screws that locate the Armrest, 2 are the once you have removed from the old part. The other 2 further forward. VW have cleverly made the armrest to be retro fitted, so there are gaps to hold the screws while fitting.
Now add the main armrest casing. There are 2 different types
1.   Will allow fitting of a Dock (IPod/USB/MDI or 6 CD changer)
2.   2. L shaped cubby hold (air cooled)
This has 2 screws Left/Right rear. The rear Air vent section pops on. Then add the rear cup holder, this again holds only 2 screws.
« Last Edit: November 03, 2014, 10:39:01 am by DamoP »
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Re: How to fit an Armrest
« Reply #1 on: November 02, 2014, 10:46:09 pm »
excellent guide Damo
Offline DamoP
  • -Receive: 115
« Reply #2 on: November 02, 2014, 10:50:19 pm »
Thanks Andy. I have loads more. Just need the time to do the write ups
Offline edd30
« Reply #3 on: November 03, 2014, 08:59:37 am »
Muchos gracias ! Great writeup. Now need to find the time to disassemble my arm rest to get to the ipod connection.
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #4 on: November 03, 2014, 11:34:11 pm »
Good write up demon
Black Ed30
Offline DamoP
  • -Receive: 115
« Reply #5 on: November 04, 2014, 07:42:11 pm »
you just need to:
cup holder off, 2 x screws
pop the rear air vent section off
armrest casing off, 2 x screws
and you can have a look at both connections
Offline DamoP
  • -Receive: 115
« Reply #6 on: November 04, 2014, 07:42:31 pm »
Good write up demon
thanks rob  :happy2:
Offline georgekeemo
« Reply #7 on: November 11, 2014, 10:32:15 pm »
Good job mate ,i was about to ask about this tut. Thanks a lot !
Offline DamoP
  • -Receive: 115
« Reply #8 on: November 12, 2014, 09:14:08 am »
Welcome mate
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #9 on: November 26, 2014, 03:56:12 pm »
Awesome guide - made my armrest and cupholder replacement so much simplier!
Cheers :happy2:
Offline DamoP
  • -Receive: 115
« Reply #10 on: November 26, 2014, 04:56:33 pm »
Cheers :happy2:
welcome dude. told you it wasn't to bad
Offline Callum45
« Reply #11 on: November 26, 2014, 05:18:04 pm »
Can you remove just the lid to change from fabric to leather or would i have to strip the whole thing down?
Offline DamoP
  • -Receive: 115
« Reply #12 on: November 26, 2014, 05:25:46 pm »
on the first pic you can see the lid and the plastic underside trim. the leather lid section can be swapped. remember the MK5 and MK6 golf have completely different lids in size and fixing so arnt compatible
Offline Callum45
« Reply #13 on: November 26, 2014, 05:34:14 pm »
How does the trim come off? Clip off or slide off?
Offline DamoP
  • -Receive: 115
« Reply #14 on: November 26, 2014, 05:35:39 pm »
you need to buy a new one/ebay one or get it trimmed
