Author Topic: When to change coolant / antifreeze?  (Read 6280 times)
Offline Tarmac_Terrorist
« on: November 03, 2014, 09:44:25 pm »
Evening all. :)
I don't seem to be able to see in the service schedule where VW replace the coolant. Just seems to be to check and top up as necessary. I thought this stuff was usually replaced every 4-5 years?
At the first cam belt change I had a new water pump fitted but the 2nd change (just a few hundred miles later) I just had the belt changed. What is the life span of these modern coolant fluids?
Offline th3_f15t
  • -Receive: 183
Re: When to change coolant / antifreeze?
« Reply #1 on: November 03, 2014, 10:11:20 pm »
I think VW list it as never being replaced, but I'd go for every 5 years personally.
« Reply #2 on: November 03, 2014, 10:21:00 pm »
Hmmm, does it not lose it's antifreeze properties then? I know the older blue stuff only had a life span of 2-3 years before it became ineffective.
« Reply #3 on: November 03, 2014, 10:55:42 pm »
afaik they should change the antifreeze when replacing the water pump.
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: November 03, 2014, 11:06:43 pm »
About 3 litres gets replaced when doing a water pump. There is about 8 litres total, but you can't get it all out for a full change.
Follow AKS tuning on Facebook
Offline OSB
  • -Given: 32
« Reply #5 on: November 04, 2014, 08:08:19 am »
Anti freeze does not loose it 'anti freeze' qualities, unless it has been diluted by topping up with water.
The older stuff would loose its corrosion properties and needed changing on a regular basis. The chemicals used for anti corrosion and the materials used in the engine and other components have negated that.
VW quality antifreeze is 'good for life' whatever that means.
It wouldn't hurt to change, but I doubt it's needed - with a certain amount of replenishment every time a cam belt / thermostat etc is changed!
« Reply #6 on: November 04, 2014, 09:46:58 pm »
Thanks fellas  :happy2:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #7 on: November 11, 2014, 01:37:10 pm »
......spot on.
