Author Topic: Massive exhaust backfire followed by engine/turbo rattle  (Read 2450 times)
Offline adzg60
« on: November 05, 2014, 06:41:27 pm »
Hi guys, I was driving home when giving the car a blip in 2nd joining a dual carriage way i had a MASSIVE! exhaust backfire. being firework night at first i thought id been hit by a rocket! I saw a fair bit but not "excessive" smoke out the back and an engine knock/rattle. I limped it home as i was close and had a quick look.
No EML on the dash, nor is it missing. The smoke now seems minimal (almost like it had over fuelled) and other than the rattle seems "ok". The noise seems to be coming from the back of the engine/underneath. Any ideas of what/where to start with.
Cars a GTI with K04
Offline adzg60
Re: Massive exhaust backfire followed by engine/turbo rattle
« Reply #1 on: November 05, 2014, 07:19:22 pm »
quick update to add,
just moved it from where i dumped it to outside my house and it splutters low down, only crawled up and giving it a little throttle its not happy.
The noise is more of a vibrating type knock/rattle that increases with rpm
« Last Edit: November 05, 2014, 07:37:41 pm by adzg60 »
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 247
« Reply #2 on: November 05, 2014, 10:05:09 pm »
Sorry to hear this mate, I don't think this will be a cheap fix  :sick:
Sounds a lot like when James blew up his BWA engine: http://www.mk5golfgti.co.uk/forum/index.php/topic,43854.msg562934.html#msg562934
Sounds like it needs looking it by a specialist  :sad1:
Offline adzg60
« Reply #3 on: November 08, 2014, 04:57:48 pm »
Done a compression test today.
1. 100psi
2. 165psi
3. 165psi
4. 165psi
So lack on compression on cylinder 1, assuming this us due to a banana shaped conrod... would have thought a damaged piston/skirt/ring/cylinder wall would yield very little compression at all?
Offline DANBOY66
  • -Given: 41
« Reply #4 on: November 08, 2014, 06:46:09 pm »
Not good fella
head off now I sapose
Dan..
