Author Topic: Rns 510 Not turning off  (Read 2197 times)
Offline EVO400
« on: November 07, 2014, 04:39:45 pm »
Hi,
Just wondering if anyone can help or came across this issue before, my Rns510 intermittently will not switch off after the ignition was turned off and key is out. radio still plays and power button not responding?
Thanks in advance
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Rns 510 Not turning off
« Reply #1 on: November 07, 2014, 04:57:51 pm »
Have you tried a soft reset? 2 arrow buttons and star/mic button pressed at the same time.
If that dont work, try unplugging the rns from the back and plug back in and see if it still plays up
Offline EVO400
« Reply #2 on: November 07, 2014, 06:11:24 pm »
Thanks.
I did a reset as above already, this is the first time it happened, wife drives the car mostly so not sure what other symptoms it was showing but yes, on occasions it will not switch off at all.
I will see now if any improvement after the soft reset.
