Author Topic: milltek shock  (Read 3477 times)
Offline biffobear
milltek shock
« on: November 07, 2014, 09:12:51 pm »
how many on here have fitted milltek downpipe and sports cats on to standard systems, thinking it was all that was required to go to a stage 2 map. this is the email I received from milltek when I enquired about buying a reducer on to standard system.
Many thanks for your email.
With regards your enquiry an adaptor is not available for the installation of the high flow downpipe and sports cat onto the OE system.
Due to the diameter differences and the restrictions within the OE system the heat build up within the downpipe and sports cat would cause damage and premature failure of the catalyst assembly, especially if used with additional hardware changes and software changes.
Regards
Leigh Ravey
Milltek Sport Ltd
Tel:  +44 (0)1332 227280
 Fax: +44 (0)1332 227289
milltek.logo.adi.award
Offline dan930
  • -Receive: 56
Re: milltek shock
« Reply #1 on: November 07, 2014, 10:38:15 pm »
Hi mate,when i had my ed30,I purchased a milltek sportscat from rtech.it is connected to the oem backbox..rtech got me a adaptor it connect it together
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline biffobear
Re: milltek shock
« Reply #2 on: November 07, 2014, 10:50:54 pm »
yes, how many others have been doing this unaware of the concequencies
Offline dan930
  • -Receive: 56
Re: milltek shock
« Reply #3 on: November 08, 2014, 01:19:56 am »
I've been running milktek sportscat with oem backbox for at least 1yr without any problems...
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: milltek shock
« Reply #4 on: November 08, 2014, 08:13:56 am »
I think if you read between the lines, there essentially trying to make you buy the back box as well as the downpipe, scare tactics at the end of day  :happy2:
Offline R9OSW
Re: milltek shock
« Reply #5 on: November 08, 2014, 09:12:38 am »
Just buy a bcs one.
Better and they offer reducers as well. No hassle
Offline vRSAlex
  • -Receive: 253
Re: milltek shock
« Reply #6 on: November 08, 2014, 10:14:06 am »
Regards
Leigh Ravey
Milltek Sport Ltd
Sounds fair to me.
Follow AKS tuning on Facebook
Offline biffobear
Re: milltek shock
« Reply #7 on: November 08, 2014, 10:34:02 am »
Do they give out a disclaimer to anyone buying the downpipe and sports cat, making them aware of the consequences of fitting them to standard system?
Offline yin
  • -Given: 77
Re: milltek shock
« Reply #8 on: November 08, 2014, 11:26:02 am »
Yes its part of the warranty disclaimer
"Please note: Milltek Sport hi-flow sports catalysts are manufactured from the highest quality materials and built with maximum performance and longevity in mind. However, they are designed to work specifically in conjunction with other Milltek Sport products and should not be used on their own (with the OEM exhaust system) or with other manufacturers exhaust systems. If the Milltek catalysts are fitted with non-Milltek exhaust systems, we are unable to provide any guarantee regarding noise quality, fit, performance or warranty against their operation."
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: milltek shock
« Reply #9 on: November 08, 2014, 01:19:29 pm »
APR & Pipewerx are happy to sell you a downpipe & sports cat which will mate to your OEM system  :happy2:
No disclaimers required.
« Last Edit: November 08, 2014, 01:21:35 pm by GrayMK5GTI »
Offline Sug
Re: milltek shock
« Reply #10 on: November 08, 2014, 01:35:51 pm »
Just buy a bcs one.
+1 mine works fine
EDITION 30 GONE, MK6 R GONE........AUDI 8V S3.....Stock for now
Offline th3_f15t
  • -Receive: 183
Re: milltek shock
« Reply #11 on: November 08, 2014, 01:45:50 pm »
I always went on the logic of getting a cat-back exhaust first then getting a downpipe and sports cat for higher performance tune.
Offline flashp
  • -Receive: 65
Re: milltek shock
« Reply #12 on: November 09, 2014, 09:01:07 am »
It was explained to me that one of the primary benefits/requirements of a full system for stage 2+ was heat (EGT) management. Their full system will dissipate heat far more quickly than a standard system and the pre-cat deletion assists in this. It can also positively impact turbo longevity for the same reasons in a tuned vehicle.
At stage 2(+) there is quite a lot of interdependence between pieces of hardware and adding certain pieces without the other may even negatively affect your state of tune, or even bring on warning lamps. From stage 1 to 2+ I tried to find a more economical route to the same result over a period of time but it would have been problematic (although probably not impossible with certain compromises) and so all the appropriate hardware went on at once. Consequently after 6 track days I've never so much as seen a warning light.
Partial system for noise, full system for a tuned vehicle would be my take on this.
You can't criticise them for warning against mis-application of hardware. They are a responsible manufacturer who have carefully developed their products.
Gone but not forgotten :-)
