Author Topic: Juddery and Lumpy on Idle Please Help  (Read 5055 times)
Offline wardygt
« on: November 09, 2014, 11:41:37 am »
Can anyone help, I have a gt tdi mk5 and the engine runs fine, but on idle the engine is very juddery and lumpy, I was told it was the maf sensor and got that replaced but it has made no difference.
what else could it be?
Offline wardygt
Re: Juddery and Lumpy on Idle Please Help
« Reply #1 on: November 09, 2014, 03:10:43 pm »
also I have disconnected battery for 30mins but didn't make any difference
anyone know what it could be?
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #2 on: November 09, 2014, 03:19:48 pm »
Could be the dual mass flywheel?
How many miles has it covered?
Offline wardygt
« Reply #3 on: November 09, 2014, 04:20:19 pm »
100k
this is exactly what it sounds like just found it on youtube
just had cambelt done and water pumper also
Offline jaye2992
« Reply #4 on: November 09, 2014, 10:24:41 pm »
When was the egr valve last cleaned?
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #5 on: November 09, 2014, 11:08:32 pm »
fault code scan?
Offline wardygt
« Reply #6 on: November 10, 2014, 10:46:05 am »
last week I thought that was the problem but hasn't made a difference  :sad1:
Offline wardygt
« Reply #7 on: November 10, 2014, 10:47:25 am »
fault code scan?
maf sensor but that has been changed but made no difference
Offline jaye2992
« Reply #8 on: November 10, 2014, 09:50:45 pm »
Used to have an A3 with the tdi engine in and mine did this badly and even used to stall. Think what i did was use aload of injector cleaner, new fuel filter and egr delete..... after that it was spot on and never did it again.
Offline wardygt
« Reply #9 on: November 11, 2014, 04:27:34 pm »
[/quote]
[/quote]
thank you
I will try that later
Offline wardygt
« Reply #10 on: January 27, 2015, 01:03:32 pm »
Hi it is in the garage it is NOT
-Injector loom
-Dirty injectors
-Maf senor
-EGR
-ECU issue
-Fuelling issue
It is becoming a mystery and is having all these different tests but still is the issue is not resolved
Does anyone know what else it could be?
Offline john87
  • -Receive: 53
« Reply #11 on: January 28, 2015, 06:58:34 pm »
PCV valve possibly need replaced? I'm sure this would cause lumpy/poor idle..
Offline boustie
« Reply #12 on: January 30, 2015, 08:36:57 pm »
Are there any faults in it ?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #13 on: January 30, 2015, 08:52:23 pm »
TDIs don't have a PCV do they?
My TDI is a bit lumpy. One thing to check is the timing torsion value and injection quantities using vcds.
If injection quantities are out it could pin point the issue to a particular cylinder.
I'm about to start checking this on mine.
Jas
VCDS (Preston, Lancashire)
Offline wardygt
« Reply #14 on: February 04, 2015, 12:50:01 am »
no faults, they are saying
all fine starting from cold until say 2mins (maybe less) of running the lumpiness starts
