Author Topic: Rear caliper piston sticking  (Read 1305 times)
Offline Stamanatic
« on: November 09, 2014, 04:27:33 pm »
Hello,
Had an issue with my rear caliper kind of sticking, I could kind of move the wheel by hand but it didn't rotate freely, had a look at the handbrake cable that was only replaced last year and is fully retracting so that's not the issue.
Then I reset the piston, wheel spun fine then, then I went a for drive to test the brakes then jacked it up again and it was back to where it was sticky, difficult to rotate by hand, so I guess the piston isn't really retracting itself.
Any ideas? Cheers
Offline daddykool
Re: Rear caliper piston sticking
« Reply #1 on: November 09, 2014, 06:36:32 pm »
I had the same problem this week, had to have new caliper fitted!
Offline AndyBrown
« Reply #2 on: November 09, 2014, 06:37:08 pm »
I had the same problem, failed mot because of it, needed a new caliper unfortunately
Offline Stamanatic
« Reply #3 on: November 10, 2014, 02:11:58 pm »
Same side? Checked the seal and it was all good and clean, pity don't see how much could go wrong with such simple engineering.
