Author Topic: Is the GTI rear ARB the same as a standard Golf?  (Read 2445 times)
Offline welshjohn
« on: November 11, 2014, 09:20:38 am »
Hi. First post so be kind!  I have had a 55 plate GTI from new and just found that the rear anti roll bar has snapped. I thought the occasional clunk from the back was probably a droplink but no, the bar has snapped in two. I drove into a layby about 4 weeks ago with a VERY big pothole and I think that's probably what did it.
So I don't want to pay out for a brand new one and I am looking at getting a scrappie bar with new droplinks and bushes. Does anyone know if the GTI bar is the same as a standard one or is it uprated?  I will probably get it posted and I am trying to avoid getting it and then finding it doesn't fit.
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
Re: Is the GTI rear ARB the same as a standard Golf?
« Reply #1 on: November 11, 2014, 01:11:01 pm »
ETKA is quoting four variants for FWD Golf's, so might be worth trying to measure yours or it's a case of going by the PR codes  :happy2: I'm guessing the GTI would have one of the two thicker ones
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #2 on: November 11, 2014, 02:10:21 pm »
I've listed this info with part nos in another thread if you can dig it out.
Most arbs are hollow, and differ in thickness.
GT / GTi models share the same one.
R models have solid arbs.
I think a Passat one can be fitted as an upgrade.
Jas
VCDS (Preston, Lancashire)
Offline xjay1337
  • -Receive: 377
« Reply #3 on: November 11, 2014, 02:16:57 pm »
Pretty sure standard ones are 20.7.
Golf V GTI: 23,6 x 3,5 / 21,7 x 3,0 both tube
Golf V R32: 22,0 solid / 21,7 x 3,0 tube (4-motion)
Golf VI GTI: 23,6 x 3,5 / 21,7 x 3,0 PR-0BF or 21,7 x 3,6 PR-0BM (DCC?) both tube
Golf VI R: 22,0 solid / 21,7 x 3,6 tube (4-motion)
Scirocco R: 23,6 x 3,5 / 21,7 x 3,6 both tube
Touran 170 HP: 23,0 solid / 21,7 x 3,0 tube
Passat R36: 23,6 solid / 21,7 x 3,6 tube (4-motion)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #4 on: November 11, 2014, 02:26:46 pm »
Ordered a GTI rear sway bar (suspension code PR-0BF) yesterday. My Golf already came from factory with the same front sway bar as the GTI. My rear sway bar has 20,7 mm x 2,8 mm (suspension code PR-0BE).
RARB part number: 1K0511409CB
Rubber bush: 2x 1K0511327AS
Offline welshjohn
« Reply #5 on: November 11, 2014, 04:19:25 pm »
Ok thanks for all your replies.
jason_rmh - Jas thanks for that. I did a search before I posted but I missed your previous post. I have found it now though and in your list it is 21.7 x 3.0.
xjay1337 - In your list it also says 21.7 x 3.0 so it's looking good.
But I think I am going to go with Golf_GT_TDI's advice and measure it just to be absolutely certain. Off out tomorrow to find some cheap calipers! (to measure with, not brake!)
Thanks everyone once again for your help.  :happy2:
John
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #6 on: November 11, 2014, 05:08:04 pm »
No need to measure. Your GTI has the one I posted: 1K0511409CB. Just order that. :wink:
If you still doubt what I'm saying you can look here to confirm: http://www.ecstuning.com/Volkswagen-Golf_V--2.0T/Suspension/View_All/ES240573/.
Offline welshjohn
« Reply #7 on: November 11, 2014, 05:27:48 pm »
Shoduchi. I think you are correct - but I suspect one of those from VW will be out of my price range which is why I am looking at a second hand one. If I could find a new one in the UK for a similar price to the one on the ECS site (about £65 by my reckoning) I would go for that but the cheapest non-VW I have seen here is about £180.
Unless anyone else knows better ??  :wink:
John
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #8 on: November 11, 2014, 06:04:58 pm »
You should try to get one posting in the Wanted section. There should be more than a couple GTI owners who upgraded their RARB and should have it available for sale.
Offline welshjohn
« Reply #9 on: November 11, 2014, 10:06:01 pm »
Good idea. I am new to the forum so I didn't know there was a Wanted section - For Sale yes but not Wanted.
I have just posted my want - fingers crossed.
Offline Golf_GT_TDI
  • -Given: 45
« Reply #10 on: November 11, 2014, 10:15:55 pm »
Might be worth contacting this seller on eBay and ask if they can relist it?..
http://www.ebay.co.uk/itm/400756923755
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #11 on: November 11, 2014, 10:32:00 pm »
That RARB isn't going to be relisted. It's coming to my Golf. :grin:
But you can keep an eye to see if they get a new one. :smiley:
