Author Topic: Wrong gear redline  (Read 4424 times)
Offline mvb12
  • -Receive: 64
Re: Wrong gear redline
« Reply #15 on: November 12, 2014, 01:19:33 pm »
fitting username too  :ashamed:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #16 on: November 12, 2014, 02:39:14 pm »
If you physically force it past the rev limiter - like changing from 5th into 1st instead of 3rd you WILL cause some damage, the rev limiter will be useless to the mechanical forces of the drivetrain.
Few Civic Type-R drivers did this
Offline madmangti
« Reply #17 on: November 12, 2014, 02:59:21 pm »
Ok, so when I do go to the garage what should I ask them to check for, if there is any potential damage? However Im still sure I put it into neutral and not 2nd gear, but it still hit into the red line regardless :(
Offline th3_f15t
  • -Receive: 183
« Reply #18 on: November 12, 2014, 05:31:13 pm »
If you'd of damaged something you'd of known about it. If it drives like normal then it's just a close call and a lesson learnt in time. :happy2: These gearboxes are pretty strong, they take high levels of tuning and daily punishment so the odd slip up isn't much to worry about.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #19 on: November 12, 2014, 09:27:22 pm »
From reading your original post, you put it in neutral rather than a lower gear. As there wasn't any drive forcing the engine beyond the limiter you have got away lightly - basically the limiter saved the engine  :happy2:
Don't bother taking it to a garage unless you notice something wrong in normal driving
dansmith180
« Reply #20 on: November 12, 2014, 09:58:02 pm »
As above these gearboxes can take a beating and if yours sounds and feels fine then don't worry, might be worth changing your gearbox oil though since its good to do anyway.
