Author Topic: Dazza's Maintenance Thread  (Read 101088 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« on: November 13, 2014, 01:32:54 pm »
Been on here a while now. Not really a build thread yet mainly maintenance stuff.
Prior to this car the most i had ever done maintenance wise was change the battery.
Single Image
First thing i noticed was the outer CV boot. Went to a few local garages who wanted to stretch a new boot on, as it had been ripped for a while this was pointless as joint would probably fail. Removing the drive shaft was easy getting the joint off was a bit of a PITA.
Single Image
Then did a basic service oil, oil filter, air filter, pollen filter and fuel filter.
And the cam follower.
Bit of work on the interior:
RNS-510 with SSD
Amp & sub
Buttons for garage and gate.
Replaced door grab handles, window switches, light switch and gear trim. (Car was previously owned by a transvestite).
Diverter Valve:
Was only getting about 9psi boost. So replaced rev B diverter valve with rev D.
By now i was gaining a bit of confidence in my DIY skills so serviced the DSG as there was no mention of it being serviced @ 80K.
Also did a bit of work on the brakes, new OEM discs all round, Hawk HPS Brake Pads and Ate Super Blue Brake Fluid. Sorry no pics of this.
Single Image
Noticed the other outer CV boot was also ripped much easier this time as i new what i was doing.
Polished out some very deep scratches on the bonnet. When i said the car was owned by a transvestite i was not joking.
Single Image
The alternator clutch pulley was f*cked this was an absolute PITA broke two torx bits trying to get this off. Got there in the end.
Although the boot handle had no white worm decided to change it for a newer one.
Did a bit more work on the interior installed a cherry red hazard switch. Messed about with some vinyl and wrapped the clocks and gear trim.
Changed the cam chain, tensioner and adjustor. Made a few mistakes with this one but got there in the end.
Added R8 Coil packs and NGK Iridium BKR7EIX Plugs.
« Last Edit: February 24, 2015, 06:00:44 pm by dazza »
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Dazza's Maintenance Thread
« Reply #1 on: November 13, 2014, 05:52:29 pm »
Finished things off today fixed the broken coil pack clip thanks to again to @bigmig95 .
Still need a piece of the split wire cover the piece the dealers gave me is to big.
Put the crappy borescope i bought on ebay to good use and found the torx bit i lost when changing the cam chain etc..
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #2 on: November 13, 2014, 06:18:22 pm »
That CF looks about ready to cave in. :confused:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #3 on: November 13, 2014, 06:36:14 pm »
It was probably the original CF @ a little less than 90k.
Also explains the slight marks on the cam lobe.
I keep coming back to the tapping noise from the HPFP. I'm sure its noisier than it should be.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: November 13, 2014, 07:15:42 pm »
If your cam lobe has slightly worn, it will eat followers  :scared:
Maybe worth checking or replacing at each service
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #5 on: November 13, 2014, 07:54:23 pm »
I will keep an eye on it. I deleted the banjo bolt which will make it a 30 second job in future.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #6 on: November 14, 2014, 10:43:36 am »
A few other things i have been working on. Feel like a chav with all these stickers :signLOL:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #7 on: November 19, 2014, 09:17:03 pm »
Need to get some fun mods installed. Will hold off on the engine mods for now and see how my cam follower holds up.
Was planning on b12s or FSD and eibach springs but my drive is a pita  :sad1:
This also affects my wheel choises as everything i like will look sh*t at this height really :sad:
How about some ARB's? Recommendations for an awesome daily drive? Mainly used on the school run!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #8 on: November 20, 2014, 10:32:30 pm »
Quick wash, clay and wax today.
Offline akbarirfan
  • -Given: 81
« Reply #9 on: November 21, 2014, 03:58:33 pm »
Great work Dazza - that's a lot of DIY you've done there!!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #10 on: November 21, 2014, 04:53:57 pm »
Thanks mate didn't think anyone was reading this.
Offline Sjw_Vw
« Reply #11 on: November 24, 2014, 02:22:55 pm »
Great DIY work :happy2:. Glad you've got the confidence and tools to do it all :smiley:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #12 on: November 24, 2014, 03:11:02 pm »
Thanks mate.
I've built up a nice collection of tools now. But i suspect my next DIY will need another specific tool that i don't have.
Offline Sjw_Vw
« Reply #13 on: November 24, 2014, 03:14:46 pm »
Thanks mate.
Yeah probably! Haha.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #14 on: November 24, 2014, 07:27:22 pm »
Koni FSD and Eibach Pro-Kits won't lower your ride much. Unless you're just entering on your drive at limit, you'll be fine. It's quite a comfortable ride setup if you choose the normal Koni FSD and not the ones for the GTI. Don't think about fitting an Ed. 30 front spoiler, it limits you a lot from entering steep garages and drives.
From what I hear from other GTI owners I'd recommend just Powerflex (purple) ARB bushes. Other aftermarket ARB already have PU bushes so you'll have even more NVH with them.
