Author Topic: Dazza's Maintenance Thread  (Read 94993 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=alokabbmbe9tp31dplk5luto33&/topic,90967.msg917089.html#msg917089
Re: Dazza's Maintenance Thread
« Reply #240 on: January 11, 2016, 07:46:44 pm »
I was told it would fit under the ashtray, it probably would if i didn't have the pipe that runs to the rear vents.
So i suppose i will have to chuck it under the wife's seat.
What are the mounting/cover options?
I've seen some with a metal mounting and plastic cover. Others with a foam insert is there a carpet cover for the foam??
05 | Tornado Red | DSG
Offline neiller
  • -Given: 32
« Reply #241 on: January 11, 2016, 08:25:41 pm »
You can buy the foam mount it sits in off eBay
Sent from my SM-N9005 using Tapatalk
Offline RBS
  • -Receive: 47
« Reply #242 on: January 11, 2016, 11:31:17 pm »
Great mats :happy2: :wink:
Yes they are a bargain. Looks A+  and you made me curious  about  the bluetooth kit!!
I'll be interested  in how it works!  Love your thread here! Great learning school!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #243 on: January 11, 2016, 11:55:38 pm »
Thanks mate. I'm always looking for the next thing to fix. I may attempt a valve cleaning later in the year for her 11th birthday.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #244 on: January 12, 2016, 01:51:51 pm »
The bluetooth kit is in. I've enabled telephone with VCDS what else do i have to do?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=alokabbmbe9tp31dplk5luto33&/topic,19740.0.html
« Reply #245 on: January 12, 2016, 02:00:51 pm »
Thats it i think
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #246 on: January 12, 2016, 02:19:01 pm »
If you don't have any errors when scanning the BT module, it should be fine and work well. :happy2:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #247 on: January 12, 2016, 02:57:43 pm »
Not working. When i get phone option on the radio. But when i go to phone on the MFD it flicks to the next screen. Could it be something to do with Polar Fis?
« Reply #248 on: January 12, 2016, 03:10:00 pm »
Did you enable the phone emulation on the Polar FIS?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #249 on: January 12, 2016, 04:49:17 pm »
 :ashamed:
Had a bit of a nightmare with the polar fis only put it back in the car today. I sent it back to polar and they said the cable was faulty and that they replaced the cable. I keep loosing the polar screen.
I've enabled the BT emulator and i now get phone initialising. Does the car have to be on to pair. My battery is flat.
« Reply #250 on: January 12, 2016, 05:03:23 pm »
Well... the radio has to be able to power on
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #251 on: January 12, 2016, 05:12:23 pm »
Managed to pair the phone with the little bit of power left in the battery. Will charge it overnight and have a play tomorrow.
Think i need a new battery.
How is the streaming set up also thought polar?
« Reply #252 on: January 12, 2016, 05:21:47 pm »
BT audio? Just setup using the Media button on the RNS510 then pressing 'BT'
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #253 on: January 12, 2016, 05:35:50 pm »
Thanks mate. Just about to order a new battery. Never heard of the one in there must be a cheapie.
Going to get one of these.
http://www.bateriaprofesional.es/es/baterias-de-arranque/48-bateria-varta-e44-77ah-silver-dynamic-780a-12v.html
« Reply #254 on: January 12, 2016, 05:41:30 pm »
Same one ive got.  :happy2:
