Author Topic: Dazza's Maintenance Thread  (Read 95083 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=suaqpi88oqmsd7n1g4d4vkvq6g&/topic,90967.msg917089.html#msg917089
Re: Dazza's Maintenance Thread
« Reply #255 on: January 12, 2016, 06:33:26 pm »
BT audio? Just setup using the Media button on the RNS510 then pressing 'BT'
I have the Bluetooth sign on the media page but its greyed out?
05 | Tornado Red | DSG
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=suaqpi88oqmsd7n1g4d4vkvq6g&/topic,19740.0.html
« Reply #256 on: January 12, 2016, 06:35:53 pm »
Hmm... pass.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #257 on: January 12, 2016, 07:05:56 pm »
I need the ignition on to make the BT module to work. Only the radio isn't enough. You need the phone sync'd and BT audio enabled in the radio Setup, maybe. I'd have to check again. It worked fine in my GTI, although I'm sure that with Polar BT is easier to work with the BT module and the cluster to configure some options.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #258 on: January 12, 2016, 07:13:11 pm »
Thanks mate so where do i enable the BT audio?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #259 on: January 12, 2016, 07:18:50 pm »
Check all the options in the Setup menu. Should be in the Media menu.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #260 on: January 12, 2016, 08:47:09 pm »
I was just being a muppet as usual.  :stupid:
When i play media on the phone the button appears.
Does this unit have voice recognition?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #261 on: January 12, 2016, 08:52:42 pm »
What parameters should polar fis have? I cant see mis 1,2 etc. Exhaust temp, lambada, and more.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #262 on: January 12, 2016, 09:12:15 pm »
The voice command of the RNS-510 is better than the voice command of the BT module. My friend who fitted my new BT module (updated the loom and coded it properly) had to disable the BT voice command for the RNS-510 to work instead. Not sure what he had to do for the button in the steering wheel start to command the radio and not the BT module. :confused:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #263 on: January 12, 2016, 09:13:25 pm »
Do you have the Advanced version?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #264 on: January 12, 2016, 09:17:35 pm »
OK will have a gander with vag com.  Can you skip tracks?
Its weird how it hijacks the sim completely so the phone cannot dial. My old blue tooth didn't used to do that.
Polar Fis +
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #265 on: January 12, 2016, 10:39:23 pm »
You bought the premium version. I preferred to get a highline module 7P6 that works well with iphones. It doesn't hijack the sim, it's more like an extension of the phone.
I have no ideas what parameters are available on the PolarFIS+, just the Advanced. I know they're fewer. :confused:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #266 on: January 12, 2016, 10:47:06 pm »
I'm sure i have the advanced. Does the + have bluetooth, mirror dip on reverse?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #267 on: January 12, 2016, 10:58:04 pm »
It is the PF03? Just checked the official site and there's no PolarFIS, just the Advanced and other different modules.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #268 on: January 12, 2016, 11:08:07 pm »
It is a PF03 but in a black metal case not plastic like on their site. They sent me a custom firmware. I cannot get the box to update so will just leave it. I even sent the box back to them and they said it was fine just the cable was faulty.
They blame the problems on my virtual machine  :stupid:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #269 on: January 12, 2016, 11:20:19 pm »
They updated the case to metal some time ago. I know the Ed. 30 has that version.
Can't you update from the site or from the update tool from another computer? It's easier with the module not connected to the CAN gateway. :confused:
