Author Topic: Emergency Advise Needed  (Read 3569 times)
Offline wayneitb
  • My Ride: MK5 GTI
« on: November 16, 2014, 01:46:11 pm »
I took the job of doing the cam follower replacement today, everything went fine apart from the Banjo Bolt, I tried to loosen the copper bolt above the Banjo Bolt which worked, but then I realised it will not undo because it is attached with a second bolt, but now the Banjo Bolt is leaking fuel, and i'm not to sure why, I have redone to bolt back up, but there is still a very small amount of fuel seeping out.
I'm now worried.
« Last Edit: November 16, 2014, 01:48:04 pm by wayneitb »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Emergency Advise Needed
« Reply #1 on: November 16, 2014, 01:57:35 pm »
I'm now worried.
Remove banjo bolt with M8 triple square tighten nut to HPFP properly then reattach the banjo bolt. If this still leaks you can have the banjo bolt and fitting that i've just removed from my car. If you pay the postage.
05 | Tornado Red | DSG
Offline wayneitb
  • My Ride: MK5 GTI
« Reply #2 on: November 16, 2014, 02:34:15 pm »
I'm now worried.
Hi Mate
Thanks for your help, Im not to sure what I have done to the bolt because I cannot get the thing undone, at the moment I have put everything back together but it's still leaking at the Banjo Bolt. I just do not know what could be wrong because everything is tightened up good.
Offline wayneitb
  • My Ride: MK5 GTI
« Reply #3 on: November 16, 2014, 03:16:27 pm »
Anyone here have any solution for a bodge job just so I can get to a garage and get this looked at, do you think I could put some silicone sealant  around the Banjo Bolt to stop the leak, or would petrol find it way out.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #4 on: November 16, 2014, 03:36:37 pm »
@wayneitb do you have a m8 tripe square?
Did you see this?
http://www.mk5golfgti.co.uk/forum/index.php/topic,78451
Offline doylebros
« Reply #5 on: November 16, 2014, 04:45:51 pm »
Offline wayneitb
  • My Ride: MK5 GTI
« Reply #6 on: November 16, 2014, 05:25:01 pm »
Thanks for the help everyone, at the moment I do not have a m8 tripe square bit so I cannot even get to the Bolt, I might just buy a replacement fuel pump and have done with it.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #7 on: November 16, 2014, 06:10:51 pm »
You will need an M8 triple square anyway. No point replacing the HPFP. Start over, remove pump properly tighten bolt to HPFP Install HPFP tighten banjo bolt.
Offline wayneitb
  • My Ride: MK5 GTI
« Reply #8 on: November 16, 2014, 07:11:23 pm »
The thing is, there is no way there should be that mush fuel coming out of the Banjo Bolt, I think I might have damaged the brass bolt which goes into the HPFP. Do you happen to know the part number for the brass bolt fixing that the Banjo Bolt is attached too?
Offline doylebros
« Reply #9 on: November 16, 2014, 07:23:55 pm »
If you click on the link above I think your referring to item 18 part number 06F127213B
If you can confirm that I'll find the dealer price for you but here's an EBay listing
http://www.ebay.co.uk/itm/GENUINE-VW-VOLKSWAGEN-2-0T-PETROL-FSI-HIGH-PRESSURE-FUEL-PUMP-UNION-06F127213B-/321192974144?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ac897d740
« Last Edit: November 16, 2014, 07:27:56 pm by doylebros »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #10 on: November 16, 2014, 07:30:29 pm »
The banjo bolt could be completely loose. I'd try refitting it before buying a new piece.
Offline wayneitb
  • My Ride: MK5 GTI
« Reply #11 on: November 16, 2014, 08:46:34 pm »
Yep, that what I'm going to do, once I get the M8 triple square tomorrow, I will take it apart and hopefully see whats going on. I will put an order in with VW for the parts just to be on the safe side. And then grovel to my boss and tell him I will not be in for a day or two.  :confused:
Offline wayneitb
  • My Ride: MK5 GTI
« Reply #12 on: November 16, 2014, 09:06:37 pm »
Yes that the part I think I need to replace.
Offline wayneitb
  • My Ride: MK5 GTI
« Reply #13 on: November 17, 2014, 05:52:44 pm »
Just like to say a big thanks for everyone advise yesterday, I managed to get that bloody Banjo Bolt out today, put everything back together, and made sure it was good an tight, and hay presto, no leaks at all. Thanks again. :happy2:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #14 on: November 17, 2014, 06:08:50 pm »
Great glad you got it sorted. I've learnt the hard way if you don't have the correct tools don't bother.
