Author Topic: Gfb dv  (Read 2531 times)
Offline W6llace
Gfb dv
« on: November 19, 2014, 03:25:50 pm »
Hi,was thinking of getting one of these divertor valves just wondering if they are any good ?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Gfb dv
« Reply #1 on: November 19, 2014, 03:54:34 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,70779.0.html
In summary:
+more robust than standard DV so shouldn't need replacing again
- costs over twice as much as stock DV
- proven to leak boost where OEM diaphragm DV doesn't
= may as well get a Rev D DV as it's less than half the price, is just as robust and will leak a bit of boost too. OEM diaphragm valves (Rev G) hold boost the best but can fail on K03 turbo'd cars (base GTI)
Offline 56OctyVRS
  • -Receive: 72
Re: Gfb dv
« Reply #2 on: November 19, 2014, 05:20:34 pm »
Id still opt for the G as even the D leaks boost as it has no seal on the plunger.
Offline th3_f15t
  • -Receive: 183
Re: Gfb dv
« Reply #3 on: November 19, 2014, 06:15:59 pm »
What sort of engine tune does the boost leak become a real issue? I have stage 1+ and my car seems to boost fine but I do hear a whooshing noise now since fitting the DV+.
Offline bimbound
Re: Gfb dv
« Reply #4 on: November 19, 2014, 07:54:09 pm »
Have there been any verified reports of these leaking since the revised version was released?
http://www.gfb.com.au/whats-new/latest-news/68-important-updates-to-dv-t9351
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Gfb dv
« Reply #5 on: November 19, 2014, 09:02:54 pm »
Not sure if anyone has tested the recent one.
Maybe worth someone doing a back to back Dyno test with a rev G  :party:
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Gfb dv
« Reply #6 on: November 20, 2014, 09:26:51 am »
I have a K03 and installed a new Rev G. Within 2 weeks I'm definitely getting a boost leak. Took it off but couldn't see much damage. Off next week so will remove and confirm then.
Offline 56OctyVRS
  • -Receive: 72
Re: Gfb dv
« Reply #7 on: November 20, 2014, 09:59:12 am »
I would check other things like the PCV valve etc. Mine ran stage 2+ for approx 40,000 miles with no issues with 1 'G' revision DV; so they are more robust than the earlier ones. If it has split after 2 weeks then take it back to the place you purchased it from.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Gfb dv
« Reply #8 on: November 20, 2014, 12:10:09 pm »
Checked PCV and it's fine. VW didn't seem at all surprised and he actually jumped at me and apologised saying that all VW parts purchased comes with a labour warranty so even though I installed it myself, if it failed they will replace and do the work too.
The catch, if they prove it is in fact ok then I have to pay them labour!
Hence my reluctance and wanting to do it myself.
Offline UTSI
Re: Gfb dv
« Reply #9 on: November 23, 2014, 06:35:57 pm »
Awesome gti and some tuners stopped using the gfb dv+ as it turns out to be a troublesome upgrade
