I did it with the car on 4 jack stands, but it was a horrible job. Wore out 7 blades cutting through the flexi pipe and DP. I had to destroy it. From what I can see, the mk5 *should* be easier, if I can get the nuts off the turbo outlet flange without it seizing or snapping the studs. I'll spray lots of plus gas on it first. I'd hate to start the job and find I snap one or more of the studs ...
Dejan, I see you have replaced the baffled turbo outlet with one without the silencer. Was it difficult to remove and fit ? It fits between the turbo and the DP ?
