Author Topic: HELP - door lock & module  (Read 964 times)
Offline Luke383
« on: November 23, 2014, 10:04:23 am »
Hi folks, just a quick NOOB question. I need to replace my passenger door lock module & a seller on ebay has asked for a part number. Is there any other way I could source the number without removing the door skin. Thanks in advance  :happy2:
« Last Edit: November 23, 2014, 12:14:12 pm by GrayMK5GTI »
Offline doylebros
Re: HELP
« Reply #1 on: November 23, 2014, 11:03:39 am »
« Last Edit: November 23, 2014, 11:07:09 am by doylebros »
Offline doylebros
Re: HELP
« Reply #2 on: November 23, 2014, 11:52:22 am »
Your inbox is full.
The most common door lock module for golfs is the part number 3D2 837 015 K near side front.
However, the correct method is to use your chassis number - build date and PR codes to identify the correct part!
Other than the above you've got to remove the part for the number.
There is a supplier on eBay doing these for just over £30 with 12 months warranty.
Hope that helps you.
Offline PND
  • -Receive: 62
Re: HELP - door lock & module
« Reply #3 on: November 23, 2014, 01:08:57 pm »
Hi Luke
I have a secondhand front passenger door lock module (3D2 837 015 K) that I bought off here that I have for sale.  I ended up selling my mk5 so I never got round to fitting it so it is now surplus to requirements.  I paid £30 for it at the time but you can have it for £18 inc 1st class p&p if that's of any use to you?
Here's a fitting guide off the forum..
http://www.mk5golfgti.co.uk/forum/index.php/topic,52585.0.html
I previously changed my rear passenger door lock module using this guide to I know it's not too bad to do!
Anyway, let me know if you want this one off me.
Paul.
