Author Topic: Mould in rear windows  (Read 1042 times)
Offline Gti man
  • -Given: 17
« on: November 23, 2014, 02:34:44 pm »
Hi
Does anyone know what to do when you get mould building up by the windows
Is there a product you can use?
Regard
Offline Stevepd
  • -Given: 49
Re: Mould in rear windows
« Reply #1 on: November 23, 2014, 04:44:48 pm »
I've got a sachet of desiccant in each window. I believe it may be quite common....
Standard 5 Door Shadow blue.
Offline Carpy25
« Reply #2 on: November 23, 2014, 04:56:32 pm »
you talking inside or outside in the gaps
a body wash brush works well on the outside in the gaps where the wash mitt won't reach  , its normally lack of sun that makes it worse in the winter months
if its in side you have a moisture problem , a sachet of desiccant as suggested will help
Rob
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #3 on: November 23, 2014, 05:32:36 pm »
I've found that using a cleaning product with enzyme eaters in it can help keep window seals from building up moss, etc. I bought ValetPro's Enzyme Odour eater when I bought a Seat Leon Cupra R interior from a smoker - got rid of the smells, and it has helped on my mk5's window seals - no green algae build up on the window rubbers.
Edition 30 - no. 1387
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #4 on: November 23, 2014, 07:15:48 pm »
I have a karcher steam cleaner I've used on all the rubbers, it works very well and doesn't do any damage as your not scrubbing. Seals work perfectly but it gets every bit of mould off
