Author Topic: EML on, goes off with battery disconx  (Read 1597 times)
Offline AndyBrown
« on: November 23, 2014, 06:24:18 pm »
Evening,
I get an intermittant fault on my 57 ED30. The engine management light comes on now and again, it goes off when the battery is disconnected.
Had it scanned tonight and there was a few codes coming up, Cooper the lad who done it said they could all be connected.
Theres no obvious symptoms with the car although I have noticed it can be a bit rough on idle once the cars stopped and out of gear (DSG)
Heres what we got from VCDS if anyone has any ideas.
5 Faults Found:
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault forPriority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 105778 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:46:25
             Freeze Frame:
                    RPM: 823 /min
                    Load: 16.9 %
                    Speed: 7.0 km/h
                    Temperature: 74.0∞C
                    Temperature: 22.0∞C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.351 V
001287 - Idle Control System RPM
               P0507 - 001 - Higher than Expected. - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 105805 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:23:21
             Freeze Frame:
                    RPM: 1078 /min
                    Load: 13.7 %
                    Speed: 0.0 km/h
                    Temperature: 81.0∞C
                    Temperature: 26.0∞C
                    Voltage: 14.224 V
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0∞C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
004243 - Bank 1; Fuel Measuring System 2
               P1093 - 008 - Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 107192 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:42:59
             Freeze Frame:
                    RPM: 1572 /min
                    Load: 12.2 %
                    Speed: 42.0 km/h
                    Temperature: 59.0∞C
                    Temperature: 18.0∞C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.478 V
008825 - Leak in Air Intake System
               P2279 - 002 -
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 107429 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:14:27
             Freeze Frame:
                    RPM: 766 /min
                    Load: 13.7 %
                    Speed: 0.0 km/h
                    Temperature: 60.0∞C
                    Temperature: 27.0∞C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.224 V
Readiness: 0000 0001
Offline AndyBrown
Re: EML on, goes off with battery disconx
« Reply #1 on: November 24, 2014, 09:02:59 pm »
Anyone?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Offline AndyBrown
« Reply #3 on: November 24, 2014, 09:49:01 pm »
Nice one.
