Author Topic: Popping......  (Read 1782 times)
Offline Johnny_tro
Popping......
« on: November 24, 2014, 07:39:00 pm »
Can some help. My heated rear window fuse keeps popping.....there does not seem to be any break in the wires coming through the tailgate.
Any ideas? Does something else use the same line? Causing it to pop?
The pop is instant as I put fuse in.
« Last Edit: November 24, 2014, 07:48:06 pm by Johnny_tro »
Offline th3_f15t
  • -Receive: 183
Re: Popping......
« Reply #1 on: November 24, 2014, 08:04:59 pm »
Take the battery off before putting a fuse in, had problems like this before but that did the trick.
Offline Johnny_tro
Re: Popping......
« Reply #2 on: November 24, 2014, 08:10:31 pm »
? Seriously
You not think there is short somewhere?
Offline W6llace
Re: Popping......
« Reply #3 on: November 24, 2014, 08:17:29 pm »
You've got a dead short , check the wiring in the tailgate first you may have the 12v supply shorting to earth, in failing that I would connected a bulb up in the fuse box and disconnect the rear screen connector if the light in the fuse box goes out then the screen is at fault, if not try to locate any connection from the fuse box to the rear screen and disconnect if the light goes out then the fault lies from the wiring back ! Hope this helps
Offline Johnny_tro
Re: Popping......
« Reply #4 on: November 24, 2014, 08:26:13 pm »
So....
1. Check wiring for breaks
2. Disconnect rear screen at tailgate
3. Get a bulb with two wires and insert this direct into fuse box
4. If comes on great news...goes put screen issue?
- if I comes on what should I check?
- if it goes out are you saying replace the rear screen?
. Casing the wires....this is a nightmare surely? Part of the main loom?
Offline W6llace
Re: Popping......
« Reply #5 on: November 24, 2014, 08:38:21 pm »
If the bulb stays on with the rear screen disconnected then the screen is ok , this is a quick way to check but if the bulb stays on then I would check the wiring but if your unsure what your doing get it booked in to a garage
Offline Johnny_tro
Re: Popping......
« Reply #6 on: November 24, 2014, 08:45:34 pm »
I'm not 100%
There is an issue....my drivers door not locking from the fob either now. Losing patients with he car  :rolleye:
Offline W6llace
Re: Popping......
« Reply #7 on: November 24, 2014, 08:54:24 pm »
Maybe connected to the blown fuse issue could be a simple fix or a nightmare but you need to know what your doing before taking it on as you could add to your dramas !!!
Offline doylebros
Re: Popping......
« Reply #8 on: November 24, 2014, 09:00:34 pm »
A good starting point would be a few details from you:-
Make
Model
Engine code
Gear box code
Year
Fuse location and fuse capacity which is blowing
This would allow the circuit diagram identification
Offline Johnny_tro
Re: Popping......
« Reply #9 on: November 24, 2014, 09:30:44 pm »
2004 mk5 gt
I will need to look in to rest
Offline golfman
  • -Given: 17
Re: Popping......
« Reply #10 on: November 25, 2014, 02:37:50 pm »
I'm not 100%
There is an issue....my drivers door not locking from the fob either now. Losing patients with he car  :rolleye:RI192742596CN
Go and visit EddieNL I'm sure he could sort you out!!!
Scott
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline Johnny_tro
Re: Popping......
« Reply #11 on: December 11, 2014, 09:05:15 pm »
Golfman - little far for me to go mate  :sad1: otherwise I would.
I did see him in August when he fitted my CCU etc.  :smiley:
Having to pay for it to be scanned / checked over  :sad1:
