Author Topic: Highline Cluster Upgrade Info and FAQ's  (Read 51328 times)
Offline skard
  • -Receive: 245
Re: Highline Cluster Upgrade Info and FAQ's
« Reply #15 on: February 11, 2015, 10:19:54 pm »
You probably don't need the MFA stalk then, if you can scroll the menu's via the OK button then the stalk is redundant
Offline MAH
« Reply #16 on: February 12, 2015, 11:16:46 am »
Offline SkyJawa
« Reply #17 on: February 12, 2015, 01:11:52 pm »
Ive fitted newer style buttons to an older speedo (970). Everything works fine. We had to go through a few of the options on VCDS however no dramas really. Now both my stalk and steering wheel control the highlime speedo however I have to use the steering wheel menu buttons to switch between audio/mfd/vehicle settings. The stalks allows controls in whichever menu is on. Some say pressing and holding up on the stalk switches between menus but I haven't tried that yet. I will find out and let you know here.
alot of folks say newer buttons wont work with a older speedo but from what I have seen that is not true.
FYI  I upgraded from a midline gti with no MFSW. I also had to upgrade the steering module as it was a midline spec.
Don't suppose at some point you can have a look on VCDS and post up what you coded?
I think I've done everything but don't think I can switch audio/mfd/vehicle settings.
970 Highline with a newer style MFSW (ok on right).
Offline usmangti
« Reply #18 on: February 12, 2015, 02:14:20 pm »
@reaper7881  fitted and coded mine. There was a bit of box ticking in the different bytes to make sure the buttons worked but it wasn't any hassle. If I see him soon I will take pics of what options have been ticked etc.
Ive got the same set of buttons. Star on the right and ok on the left.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #19 on: February 12, 2015, 02:23:41 pm »
@usmangti If this can work, it would solve a lot of hassle with people trying to self code early clusters.
Offline usmangti
« Reply #20 on: February 12, 2015, 02:43:40 pm »
Yeah no probs. Need to see Reaper soon as need some stuff doing. Maybe even saturday :happy2:
Offline corjinovschi@gmail.com
« Reply #21 on: February 17, 2015, 04:15:13 pm »
Yes well i have installed the high-end cluster, done all the basic settings but i don't manage to get the menu button on the mfsw to work. I have tried every coding there is on the steering wheel. Should I buy a stalk and sell my wheel?
Trimis de pe al meu Xperia SP folosind Tapatalk
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #22 on: February 17, 2015, 04:21:29 pm »
Whats the part number of the highline cluster? If you dont have a wiper stalk with the rocker buttons, chances are you have a lowline steering wheel control module. You would need a midline module to use the wiper stalk rocker button or a Highline control module to use the buttons on the steering wheel
« Reply #23 on: February 17, 2015, 05:25:09 pm »
I have a high end steering module, a new type mfsw, cruise control and, of course, a 2004 cluster full display. I haven't bought a stalk yet hopping the buttons on the mfsw would work.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #24 on: February 17, 2015, 07:11:27 pm »
you would probably need a newer highline display ending in 973 or 974.  although others have managed to use older clocks with mfsw. not sure how.
Offline usmangti
« Reply #25 on: February 17, 2015, 07:38:38 pm »
Yeah strange its not worked. Could be steering slip ring too if lowline equipment previously?
« Reply #26 on: February 18, 2015, 07:08:05 am »
Could someone with both mfsw and high line cluster tell me the codding on the steering? Maybe i got it wrong ....
Someone told me to update soft version on my clusters. This is what i have:
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 971 A
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0007103
   Shop #: WSC 00445 067 57207
   VCID: 29591B2F800CF950575
and i need to change it to SW4312
Can i do this by myself or do i need to go to a VW service?
« Last Edit: February 18, 2015, 07:21:09 am by corjinovschi@gmail.com »
Offline Ben_VTR
« Reply #27 on: April 13, 2017, 10:26:46 am »
Hi All,
I have a 2007 DSG Jetta 2.0 TFSI, with midline clocks, stalk buttons and cruise control.
I'm looking to upgrade to GTI Highlines, and also install a GTI MSFW with paddles.
What clocks do I need to buy? And also is there anything else I need to get? Will I need the highline control module aswell to use the MFSW buttons?
Thanks, Ben.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #28 on: April 13, 2017, 11:23:35 am »
Hi All,
Thanks, Ben.
Hey Ben,
You can buy any highline cluster, but for the menu button to work you will need one with part number ending in 972,9873 or 974.
Alex Retro (Olsen-72) can supply and fit them for you
In regards to MFSW, yes you will need a Highline one. Follow this youtube video.
Offline SeyiiOluwa
« Reply #29 on: April 13, 2017, 03:10:28 pm »
Hi All,
Thanks, Ben.
Hey Ben, I've got a set of highlines if you're interested
