Author Topic: Clutch Master Cylinder?  (Read 5230 times)
Offline Gasman
« on: November 25, 2014, 09:04:33 pm »
Evening all,
My clutch now engages about an inch off the floor and when it's cold the clutch pedal doesn't return all the way up it gets stuck half way up.  I've had no other problems the clutch isn't slipping, no loss of fluid either so I'm thinking it's the master cylinder.  Anyone come across this?
Steel Grey GTI, 19" BBS RD383 wheels, R32 rear bumper, BCS R32 style cat back
Offline SiofChester
Re: Clutch Master Cylinder?
« Reply #1 on: November 25, 2014, 09:10:46 pm »
Can you try pumping the pedal before trying to engage a gear, does that change things at all?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: November 25, 2014, 09:15:03 pm »
My clutch acts up when the engine bay gets hot, my biting point gets lower (to about an inch off the floor) making it difficult to engage first and get out of reverse  :fighting:
I'm thinking it's master cylinder causing this.
Sorry I can't help any more with your issue, but I think your in the right ballpark.
@vRSAlex is looking at mine in January so I'll report back  :happy2:
Offline Gasman
« Reply #3 on: November 25, 2014, 09:25:12 pm »
Tried this but it doesn't change it at all.  Once the car has been running for about ten minutes it returns fine but the biting point is still low.
Offline Gasman
« Reply #4 on: November 25, 2014, 09:28:38 pm »
Ok mate thanks. I'm going to get mine looked at soon so I'll let you know what the outcome is.  Any idea how much a garage will charge to fit a master cylinder?  They are £50 on euro car parts and I'm thinking about an hours labour on top?
Offline howie1987
  • -Given: 92
  • -Receive: 20
« Reply #5 on: November 25, 2014, 11:51:48 pm »
I changed one recently mate. An hour tops.
Try buying from carpartsforless. Its cheaper but its eurocarparts that own it so same parts.
Hope you get it sorted.
Offline Gasman
« Reply #6 on: November 28, 2014, 06:44:48 pm »
Thanks mate.  I spoke to the previous owner who said he had the master cylinder changed a couple of years ago so he doesn't think it's going to be that?  I'm thinking it's going to be the slave cylinder.
