Author Topic: De-activate rear wiper?  (Read 3029 times)
Offline K9
  • VW LifeStyle
« on: November 28, 2014, 09:34:30 pm »
how do i de-activate the rear wiper from vcds or is there another way to do this? as google didn't answer my questio  :indifferent:
Offline olsen-72
  • -Receive: 21
  • Redditch
Re: De-activate rear wiper?
« Reply #1 on: November 29, 2014, 09:37:47 am »
In address 09 Centr.Electr.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline K9
  • VW LifeStyle
« Reply #2 on: November 29, 2014, 11:52:32 am »
wich one there is the rear wiper? as i once tried to deactivate it and the front screen washer stoped to work  :scared:
Offline Matto
  • -Receive: 116
« Reply #3 on: November 29, 2014, 12:14:45 pm »
There is a bit labelled as "Rear Wiper Installed". Not sure if unchecking that would deactivate the rear wiper or not.
Offline K9
  • VW LifeStyle
« Reply #4 on: November 29, 2014, 12:23:06 pm »
i tried that, ended up that the front windwscreen washer dont work  :fighting:
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #5 on: November 30, 2014, 12:24:48 am »
So obviously you did something wrong
Offline K9
  • VW LifeStyle
« Reply #6 on: December 01, 2014, 04:21:54 pm »
tried everything what have "rear wiper" in it's name to activate or deactivate  :confused:
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #7 on: December 01, 2014, 04:24:05 pm »
Rear Wiper Fitted/Installed
Offline K9
  • VW LifeStyle
« Reply #8 on: December 01, 2014, 04:35:29 pm »
yeap. tried to unchekc that, but ended up that front windscreen washer dont work.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #9 on: December 01, 2014, 04:42:18 pm »
Cant remember from top of my head now but i think there is also an option in address 16-Steering Wheel. Last digit
Offline K9
  • VW LifeStyle
« Reply #10 on: December 01, 2014, 04:55:54 pm »
ok thx will check that tomorrow
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #11 on: December 01, 2014, 07:37:27 pm »
BTW, can you post here your scan from address 09. I need your your codding and P/N
There is example from my old car. Your one can be similar
Byte 1 - Bit 3 and 7 - Untick
Byte 2 - Bit 0 - Untick
Also Change the coding in Address 16 - Steering wheel. Last digit change from 2 to 1.
